No OpenPlex menubar icon
I’ve tried to install OpenPlex three times. Each time, the installer message says to click the menubar icon to continue. My problem is that there is no OpenPlex icon on the menubar. How do I fix this?
@wahlman.j said:
Ok here is a work around until the installer app is fixed, run the following scripts via script editor:
Part1
After the Part1 script completes (I believe Part1 script will end with the result “”) run the ProgressLabel script over and over again (until the ProgressLabel script says “Cloning OpenPlex Complete”)
ProgressLabel
Last run Part3 (OpenPlex will display in the menubar when it has been successfully installed):
Part3
When we have time to fix the bug(s) they will be resolved, until then sorry for the inconvenience.
Video example:
https://www.youtube.com/watch?v=Cm2O8o1qWj4
@Blim5001 Looks like you have a issue with launchctl, reboot your machine and try to run the scripts again:
03/05/2016 19:18:43.130 com.apple.xpc.launchd[1]: (com.plex.plexconnect.bash[7505]) Service exited with abnormal code: 127
That did the trick! The setup was a little tedious, but it’s working on all three aTV’s. Thanks!
