I am seeing playback activity.
The transcoder is running to make the file so it can be played back.
It is working ok.
What are you trying to play this on?
Aug 19, 2020 00:47:12.828 [0x7fe48df76700] DEBUG - Selecting best audio stream for part ID 19250 (autoselect: 1 language: en)
Aug 19, 2020 00:47:12.828 [0x7fe48df76700] DEBUG - Audio Stream: 36474, Subtitle Stream: -1
Aug 19, 2020 00:47:12.829 [0x7fe48df76700] DEBUG - MDE: Selected protocol dash; container: mp4
Aug 19, 2020 00:47:12.829 [0x7fe48df76700] DEBUG - MDE: analyzing media item 19215
Aug 19, 2020 00:47:12.829 [0x7fe48df76700] DEBUG - MDE: For Colored Girls (2010): Direct Play is disabled
Aug 19, 2020 00:47:12.829 [0x7fe48df76700] DEBUG - MDE: For Colored Girls (2010): media must be transcoded in order to use the dash protocol
Aug 19, 2020 00:47:12.829 [0x7fe48df76700] DEBUG - MDE: For Colored Girls (2010): no direct play video profile exists for http/mkv/h264
Aug 19, 2020 00:47:12.829 [0x7fe48df76700] DEBUG - MDE: For Colored Girls (2010): no direct play video profile exists for http/mkv/h264/dca
Aug 19, 2020 00:47:12.829 [0x7fe48df76700] DEBUG - MDE: Cannot direct stream audio stream due to codec dca when profile only allows aac
Aug 19, 2020 00:47:12.829 [0x7fe48df76700] DEBUG - MDE: For Colored Girls (2010): selected media 0 / 19215
Aug 19, 2020 00:47:12.829 [0x7fe45a203700] DEBUG - Killing job.
Aug 19, 2020 00:47:12.829 [0x7fe45a203700] DEBUG - Signalling job ID 20520 with 9
Aug 19, 2020 00:47:12.829 [0x7fe45a203700] DEBUG - Job was already killed, not killing again.
Aug 19, 2020 00:47:12.829 [0x7fe45a203700] DEBUG - Stopping transcode session rfde8ohwgvnc22isiwixqma5
Aug 19, 2020 00:47:12.829 [0x7fe494734700] DEBUG - Cleaning directory for session rfde8ohwgvnc22isiwixqma5 (/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-rfde8ohwgvnc22isiwixqma5-f08587e2-9c8b-4de4-b6a3-b877c7702148)
Aug 19, 2020 00:47:12.831 [0x7fe45a203700] DEBUG - Transcoder: Cleaning old transcode directories.
Aug 19, 2020 00:47:12.831 [0x7fe45a203700] DEBUG - Transcoder: Cleaning old transcode directory: "/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-rfde8ohwgvnc22isiwixqma5-f08587e2-9c8b-4de4-b6a3-b877c7702148"
Aug 19, 2020 00:47:12.829 [0x7fe48df76700] DEBUG - Streaming Resource: Session 0x7fe464202470:f05nvea9khq3mokgz47cp8xt changed transcode slot usage to not used. Used slots is now 0
Aug 19, 2020 00:47:12.834 [0x7fe45a203700] DEBUG - Whacked session rfde8ohwgvnc22isiwixqma5, 0 remaining.
Aug 19, 2020 00:47:12.834 [0x7fe48df76700] DEBUG - Streaming Resource: Reached Decision id=16392 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=19215 part=(id=19250 decision=transcode container=mp4 protocol=dash streams=(Video=(id=36473 decision=copy width=1920 height=1080) Audio=(id=36474 decision=transcode bitrate=256 encoder=aac channels=2 rate=48000))))
Aug 19, 2020 00:47:12.835 [0x7fe4952ec700] DEBUG - Completed: [192.168.178.49:53163] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F16392&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=iwf4wt9tf6s5qhfsyok1ja7m&subtitles=burn&Accept-Language=en (7 live) GZIP 12ms 2927 bytes (pipelined: 107)
Aug 19, 2020 00:47:12.841 [0x7fe4955da700] DEBUG - Auth: authenticated user 1 as tigg3rtam
Aug 19, 2020 00:47:12.841 [0x7fe459c27700] DEBUG - Request: [192.168.178.49:53163 (Subnet)] GET /status/sessions (7 live) GZIP Signed-in Token (tigg3rtam)
Aug 19, 2020 00:47:12.841 [0x7fe459c27700] DEBUG - [Now] Adding 1 sessions.
Aug 19, 2020 00:47:12.842 [0x7fe4952ec700] DEBUG - Completed: [192.168.178.49:53163] 200 GET /status/sessions (7 live) GZIP 1ms 3286 bytes (pipelined: 108)
Aug 19, 2020 00:47:12.843 [0x7fe49cc59700] DEBUG - Jobs: '/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Transcoder' exit code for process 20520 is -9 (signal: Killed)
Aug 19, 2020 00:47:12.898 [0x7fe4955da700] DEBUG - Auth: authenticated user 1 as tigg3rtam
Aug 19, 2020 00:47:12.899 [0x7fe48f159700] DEBUG - Request: [192.168.178.49:53163 (Subnet)] GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F16392&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=iwf4wt9tf6s5qhfsyok1ja7m&subtitles=burn&Accept-Language=en (6 live) GZIP Signed-in Token (tigg3rtam)
Aug 19, 2020 00:47:12.899 [0x7fe48f159700] DEBUG - Found session GUID of iwf4wt9tf6s5qhfsyok1ja7m in session start.
Aug 19, 2020 00:47:12.899 [0x7fe48f159700] DEBUG - TranscodeUniversalRequest: using augmented profile Web
Aug 19, 2020 00:47:12.899 [0x7fe48f159700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/16392?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=f05nvea9khq3mokgz47cp8xt
Aug 19, 2020 00:47:12.899 [0x7fe48f159700] DEBUG - Auth: authenticated user 1 as tigg3rtam
Aug 19, 2020 00:47:12.904 [0x7fe48f159700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Aug 19, 2020 00:47:12.904 [0x7fe48f159700] DEBUG - Selecting best audio stream for part ID 19250 (autoselect: 1 language: en)
Aug 19, 2020 00:47:12.904 [0x7fe48f159700] DEBUG - Audio Stream: 36474, Subtitle Stream: -1
Aug 19, 2020 00:47:12.905 [0x7fe48f159700] DEBUG - Found session GUID of iwf4wt9tf6s5qhfsyok1ja7m in session start.
Aug 19, 2020 00:47:12.905 [0x7fe48f159700] DEBUG - Cleaning directory for session iwf4wt9tf6s5qhfsyok1ja7m ()
Aug 19, 2020 00:47:12.905 [0x7fe48f159700] DEBUG - Starting a transcode session iwf4wt9tf6s5qhfsyok1ja7m at offset -1.0 (state=3)
Aug 19, 2020 00:47:12.906 [0x7fe48f159700] DEBUG - TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Aug 19, 2020 00:47:12.906 [0x7fe48f159700] DEBUG - [Universal] Using local file path instead of URL: /share/CACHEDEV1_DATA/homes/admin/Medi@/Flix/FLIX/For Colored Girls (2010).mkv
Aug 19, 2020 00:47:12.906 [0x7fe48f159700] DEBUG - TPU: hardware transcoding: final decoder: , final encoder:
Aug 19, 2020 00:47:12.906 [0x7fe48f159700] DEBUG - Job running: EAE_ROOT='/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/tmp/pms-26639379-89e2-421c-8dbf-6d6a97d82bba/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex\ Media\ Server/Codecs/5f603a2-3204-linux-x86_64/' XDG_CACHE_HOME='/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Cache' XDG_DATA_HOME='/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Transcoder' '-codec:0' 'h264' '-codec:1' 'dca' '-ss' '0' '-noaccurate_seek' '-analyzeduration' '20000000' '-probesize' '20000000' '-i' '/share/CACHEDEV1_DATA/homes/admin/Medi@/Flix/FLIX/For Colored Girls (2010).mkv' '-filter_complex' '[0:1] aresample=async=1:ocl='\''stereo'\'':rematrix_maxval=0.000000dB:osr=48000[0]' '-map' '0:0' '-metadata:s:0' 'language=eng' '-codec:0' 'copy' '-map' '[0]' '-metadata:s:1' 'language=eng' '-codec:1' 'aac' '-b:1' '256k' '-f' 'dash' '-seg_duration' '5' '-init_seg_name' 'init-stream$RepresentationID$.m4s' '-media_seg_name' 'chunk-stream$RepresentationID$-$Number%05d$.m4s' '-window_size' '5' '-delete_removed' 'false' '-skip_to_segment' '1' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/manifest?X-Plex-Http-Pipeline=infinite' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'dash' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress'
Aug 19, 2020 00:47:12.906 [0x7fe48f159700] DEBUG - Jobs: Starting child process with pid 20830
Aug 19, 2020 00:47:12.909 [0x7fe459939700] DEBUG - Request: [127.0.0.1:39650 (Loopback)] PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress?status=startup (7 live) Signed-in Token (tigg3rtam) (range: bytes=0-)
Aug 19, 2020 00:47:12.909 [0x7fe4955da700] DEBUG - Completed: [127.0.0.1:39650] 204 PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress?status=startup (7 live) 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Aug 19, 2020 00:47:12.916 [0x7fe48c806700] DEBUG - Request: [127.0.0.1:39650 (Loopback)] PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress?status=startup (7 live) Signed-in Token (tigg3rtam) (range: bytes=0-)
Aug 19, 2020 00:47:12.916 [0x7fe4952ec700] DEBUG - Completed: [127.0.0.1:39650] 204 PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress?status=startup (7 live) 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Aug 19, 2020 00:47:12.916 [0x7fe48df76700] DEBUG - Request: [127.0.0.1:39650 (Loopback)] PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress?status=opening (7 live) Signed-in Token (tigg3rtam) (range: bytes=0-)
Aug 19, 2020 00:47:12.916 [0x7fe4952ec700] DEBUG - Completed: [127.0.0.1:39650] 204 PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress?status=opening (7 live) 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Aug 19, 2020 00:47:12.917 [0x7fe459c27700] DEBUG - Request: [127.0.0.1:39650 (Loopback)] PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress?status=opened (7 live) Signed-in Token (tigg3rtam) (range: bytes=0-)
Aug 19, 2020 00:47:12.917 [0x7fe4955da700] DEBUG - Completed: [127.0.0.1:39650] 204 PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress?status=opened (7 live) 0ms 203 bytes (pipelined: 4) (range: bytes=0-)
Aug 19, 2020 00:47:12.918 [0x7fe459939700] DEBUG - Request: [127.0.0.1:39650 (Loopback)] PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress/stream?index=0&id=0&codec=h264&type=video (7 live) Signed-in Token (tigg3rtam) (range: bytes=0-)
Aug 19, 2020 00:47:12.918 [0x7fe4952ec700] DEBUG - Completed: [127.0.0.1:39650] 200 PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress/stream?index=0&id=0&codec=h264&type=video (7 live) 0ms 195 bytes (pipelined: 5) (range: bytes=0-)
Aug 19, 2020 00:47:12.918 [0x7fe48c806700] DEBUG - Request: [127.0.0.1:39650 (Loopback)] PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress/stream?index=1&id=0&codec=dts&type=audio (7 live) Signed-in Token (tigg3rtam) (range: bytes=0-)
Aug 19, 2020 00:47:12.918 [0x7fe4955da700] DEBUG - Completed: [127.0.0.1:39650] 200 PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress/stream?index=1&id=0&codec=dts&type=audio (7 live) 0ms 195 bytes (pipelined: 6) (range: bytes=0-)
Aug 19, 2020 00:47:12.918 [0x7fe48df76700] DEBUG - Request: [127.0.0.1:39650 (Loopback)] PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress/stream?index=2&id=0&codec=dts&type=audio (7 live) Signed-in Token (tigg3rtam) (range: bytes=0-)
Aug 19, 2020 00:47:12.918 [0x7fe4952ec700] DEBUG - Completed: [127.0.0.1:39650] 200 PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress/stream?index=2&id=0&codec=dts&type=audio (7 live) 0ms 195 bytes (pipelined: 7) (range: bytes=0-)
Aug 19, 2020 00:47:13.055 [0x7fe459c27700] DEBUG - Request: [127.0.0.1:39650 (Loopback)] PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress/streamDetail?index=0&id=0&codec=h264&type=video&profile=High&language=eng&width=1920&height=1080&interlaced=0&sar=1:1&level=41&frameRate=23.976 (7 live) Signed-in Token (tigg3rtam) (range: bytes=0-)
Aug 19, 2020 00:47:13.056 [0x7fe4955da700] DEBUG - Completed: [127.0.0.1:39650] 200 PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress/streamDetail?index=0&id=0&codec=h264&type=video&profile=High&language=eng&width=1920&height=1080&interlaced=0&sar=1:1&level=41&frameRate=23.976 (7 live) 0ms 195 bytes (pipelined: 8) (range: bytes=0-)
Aug 19, 2020 00:47:13.056 [0x7fe459939700] DEBUG - Request: [127.0.0.1:39650 (Loopback)] PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress/streamDetail?index=1&id=0&codec=dts&type=audio&bitrate=1536000&profile=DTS-HD%20MA&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000&bitDepth=24&disp_default=1 (7 live) Signed-in Token (tigg3rtam) (range: bytes=0-)
Aug 19, 2020 00:47:13.056 [0x7fe4955da700] DEBUG - Completed: [127.0.0.1:39650] 200 PUT /video/:/transcode/session/iwf4wt9tf6s5qhfsyok1ja7m/8e9ea55b-a42e-4b72-85f3-c7001509df70/progress/streamDetail?index=1&id=0&codec=dts&type=audio&bitrate=1536000&profile=DTS-HD%20MA&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000&bitDepth=24&disp_default=1 (7 live) 0ms 195 bytes (pipelined: 9) (range: bytes=0-)
