No Plex servers discovered
PlexConnect is does not work anymore on my ATV (7.0.1), because there is no Plex Library Sections Available.
Here the terminal details:
20:08:27 PlexAPI: ***
20:08:28 PlexAPI: GDM: No servers discovered
20:08:28 PlexAPI: Servers (local+MyPlex): 0
20:08:28 DNSServer: DNS request received!
20:08:28 DNSServer: Source: ('192.168.0.25', 54662)
20:08:28 DNSServer: Domain: init-cdn.itunes-apple.com.akadns.net
20:08:28 DNSServer: ***forward request
20:08:28 WebServer: serving .xml: /PlexConnect.xml
20:08:28 DNSServer: -> DNS response from higher level
20:08:28 WebServer: serving /js/utils.js
20:08:28 WebServer: serving .xml: /library/sections
20:08:29 DNSServer: DNS request received!
20:08:29 DNSServer: Source: ('192.168.0.25', 53025)
20:08:29 DNSServer: Domain: itunes-cdn.itunes-apple.com.akadns.net
20:08:29 DNSServer: ***forward request
20:08:29 WebServer: serving /js/sectionHoldSelect.js
20:08:29 DNSServer: -> DNS response from higher level
20:08:29 DNSServer: Source: ('192.168.0.25', 63032)
20:08:29 DNSServer: Domain: mzuserxp.itunes-apple.com.akadns.net
It seems that PlexConnect is not able to reach my Plex server, instead it is running...
Could you help me?
>>It seems that PlexConnect is able to reach my Plex server...
How do those two go together? aTV can reach PlexConnect... but then?
Sorry I mean not able to reach my Plex server... And the ATV I have this message : no Plex Library Sections Available...
Have you enabled Plex Home on your PMS?
No Plex Pass?
I'll check if Plex Home is enabled on my PMS. No I don't have anymore the Plex Pass, is it mandatory to use PlexConnect?
It is really strange, I just stop during over the night my PMS (installed on a Mac Mini Yosemite) and run Onyx… Since that, I have this issue.
By editing the "Setting.cfg" file as is:
enable_plexgdm = False
ip_pms = 127.0.0.1
port_pms = 32400
I'm able to reach my PMS but afterword nothing is working. I don't have the cover and I'm not able to read any content...
Please help :D
Plex Pass is not needed for PlexConnect. But for Plex Home.
Yeah... ip_pms=127.0.0.1 really isn't right. 127.0.0.1 is always "self" or the ping back address. PlexConnect might work, but your aTV definitively wouldn't find your PMS at 127.0.0.1.
In PMS, do you "require authentication"?
On aTV, did you sign out of MyPlex?
