I had PlexConnect set up a long time ago in a different house with a different internet provider and modem router combination. We've since moved and I figured it would be easier to start from scratch rather than try to change an existing installation.
I wiped my aTV and deleted all part of PlexConnect from my computer.
I then used OpenPlex for the setup. I think I did everything right but on my aTV all I get is "No Plex Available"
Your ATV model (2 or 3) and firmware version: aTV 2 v6.2.1
The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.1.2
The local IP address of the device that PlexConnect is installed on: 192.168.1.2
The device and operating system (including version number) that PlexConnect is installed on: iMac w/ OS X 10.10.4
The device and operating system (including version number) that the Plex media server (PMS) is installed on: iMac w/ OS X 10.10.4
The Plex media server (PMS) version number you are running (do not put 'latest'): 0.9.14.4
The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.2
The PlexConnect version number: 0.5
The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c)
[PlexConnect] enable_plexgdm = True ip_pms = 192.168.178.10 port_pms = 32400 enable_dnsserver = True port_dnsserver = 53 ip_dnsmaster = 8.8.8.8 prevent_atv_update = True enable_plexconnect_autodetect = True ip_plexconnect = 0.0.0.0 hosttointercept = trailers.apple.com port_webserver = 80 enable_webserver_ssl = True port_ssl = 443 certfile = ./assets/certificates/trailers.pem allow_gzip_atv = False allow_gzip_pmslocal = False allow_gzip_pmsremote = True loglevel = Normal logpath = .
