No signal
What if I do not have any signal from an antenna, but I am definitely in a service area for OTA? I cannot believe there is no info on this. So can I still stream local channels if I am in the service area but cannot pick up channels with an antenna? I have tried boosters and expensive antennas and I can only get 1-5 channels due to trees, hills and distance.
Unfortunately, this is the reality of over-the-air broadcasts – physical and geographical obstacles will interfere with the broadcast signal and there really isn’t anything you can do about it short of raising a very tall antenna structure, either on your roof or in your backyard.
