Hello Plex Staff, my app just got updated over the weekend. The msg came to enable the new player. Which I did. But now I get no sound. Then I reverted back to the old player and the sound is back. So clearly something about the new player is causing this. I am on a T5 box running Android TV version 9. I have 3 boxes and all don’t work with the new player. A friend has a google certified Mi Box and he is fine for some reason. He has the new player enabled and the sound is working for him. Its the same MKV content (he ran the exact same file for me). Is this a known issue? When will this be fixed?
I dont think thats a known issue you should post the android logs after playing something on new player.
Ok will do. Was there any detailed announcement on the new Player? What is it and why it was added, etc. Maybe that might give a clue to what is going on here. I somehow missed it if it was sent. Or if there are any release notes. Its not clear why they suddenly decided to update the player. I am sure they are trying to make it better, etc. But not sure how to communicate with them to report the issues.
here is the log. The key issue is that it is not able to update the audio drivers. On some boxes the app says “Updating Player support” and then it works fine. But on others it does not do anything. But if I disable the new player, everything works fine.
12-14 19:07:45.184 i: [FF] Container[hls] No Title - 0 kbps, 42 mins [CT: 0us, ST: 10080000us, SRT: -9223372036854775808us].
12-14 19:07:45.193 i: [FF] VideoStream[0-hevc] 1920x1080 [SAR 1:1, DAR 1920:1080]. H.265 / HEVC (High Efficiency Video Coding) - Unknown Profile (video/hevc), 1.4 Mbps -54 secs 25.00fps, No Title / Unknown (null), 0 bytes, .
12-14 19:07:45.194 i: [FFmpeg] [INFO] Successfully opened https://192.168.1.42:32400/video/:/transcode/universal/start.m3u8?audioBoost=180&autoAdjustQuality=0&directPlay=0&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&includeCodecs=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=91712&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F7501&protocol=hls&session=b4d670e467dc2da9-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160&X-Plex-Client-Identifier=b4d670e467dc2da9-com-plexapp-android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoAudioCodec%26scopeName%3Daac%26type%3DupperBound%26name%3Daudio.channels%26value%3D30%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain|main%2010)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)&X-Plex-Device=VIM1&X-Plex-Platform=Android&X-Plex-Platform-Version=9&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Supported-Commands=abort&X-Plex-Token=...GrVa&X-Plex-Version=7.25.3.14365, finding 2 streams.
12-14 19:07:45.221 i: [FFmpeg] [INFO] Input #0, hls, from ‘’:
12-14 19:07:45.222 i: [FFmpeg] [INFO] Duration:
12-14 19:07:45.223 i: [FFmpeg] [INFO] 00:42:05.00
12-14 19:07:45.224 i: [FFmpeg] [INFO] , start:
12-14 19:07:45.225 i: [FF] AudioStream[1-ac3] 6 channels over 1551 (5.1(side)), 48000 Hz, 0,0 padding. ATSC A/52A (AC-3) - Unknown Profile (audio/ac3), 1.4 Mbps -54 secs 0.00fps, No Title / Unknown (null), 0 bytes, .
12-14 19:07:45.228 i: [FFmpeg] [INFO] 10.080000
12-14 19:07:45.242 i: [FFmpeg] [INFO] , bitrate:
12-14 19:07:45.243 i: [FFmpeg] [INFO] N/A
12-14 19:07:45.244 i: [FFmpeg] [INFO]
12-14 19:07:45.244 i: [FFmpeg] [INFO] Program 0
12-14 19:07:45.251 i: [FFmpeg] [INFO] Metadata:
12-14 19:07:45.252 i: [FFmpeg] [INFO] variant_bitrate :
12-14 19:07:45.254 i: [FFmpeg] [INFO] 1392000
12-14 19:07:45.255 i: [FFmpeg] [INFO] Stream #0:0
12-14 19:07:45.256 i: [FFmpeg] [INFO] : Video: hevc (Main 10), 1 reference frame (HEVC / 0x43564548), none, 1920x1080 (0x0), 0/1
12-14 19:07:45.257 i: [FFmpeg] [INFO] ,
12-14 19:07:45.258 i: [FFmpeg] [INFO] 25 fps,
12-14 19:07:45.259 i: [FF] Video decoder doesn’t support ac3 (audio/ac3).
12-14 19:07:45.274 i: [FFmpeg] [INFO] 25 tbr,
12-14 19:07:45.278 i: [FFmpeg] [INFO] 90k tbn,
12-14 19:07:45.279 i: [FFmpeg] [INFO] 90k tbc
12-14 19:07:45.280 i: [FF] Audio decoder doesn’t support ac3 (audio/ac3).
12-14 19:07:45.280 i: [FFmpeg] [INFO]
12-14 19:07:45.281 i: [FFmpeg] [INFO] Metadata:
12-14 19:07:45.281 i: [FFmpeg] [INFO] variant_bitrate :
12-14 19:07:45.283 i: [FF] Video decoder doesn’t support hevc (video/hevc).
12-14 19:07:45.284 i: [FFmpeg] [INFO] 1392000
12-14 19:07:45.286 i: [FFmpeg] [INFO]
12-14 19:07:45.286 i: [FFmpeg] [INFO] Stream #0:1
12-14 19:07:45.288 i: [FFmpeg] [INFO] : Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, 5.1(side), s16p, 384 kb/s
12-14 19:07:45.291 i: [FFmpeg] [INFO]
12-14 19:07:45.292 i: [FFmpeg] [INFO] Metadata:
12-14 19:07:45.293 i: [FF][MediaPeriod] Selecting tracks.
12-14 19:07:45.294 i: [FFmpeg] [INFO] variant_bitrate :
12-14 19:07:45.294 i: [FFmpeg] [INFO] 1392000
12-14 19:07:45.295 i: [FFmpeg] [INFO]
12-14 19:07:45.295 i: [FFmpeg] [INFO] Container metadata entries found: 0.
12-14 19:07:45.296 i: [FFmpeg] [INFO] Stream metadata entries found: 1.
12-14 19:07:45.296 i: [Player][LoadControl] Assumed Bitrate: 400000, Segment Count: 46875
12-14 19:07:45.297 i: [FFmpeg] [INFO] Stream metadata entries found: 1.
12-14 19:07:45.297 i: [Player][LoadControl] Detected memory pressure, reducing segment count to fit available memory: 224
12-14 19:07:45.298 i: [Player][LoadControl] Segment count: 1433
12-14 19:07:45.299 i: [ExoPlayer][EventLogger] decoderEnabled [7.07, 0.00, window=0, video]
12-14 19:07:45.301 i: [ExoPlayer][EventLogger] decoderEnabled [7.07, 0.00, window=0, audio]
12-14 19:07:45.301 i: [MediaCodecVideoSyncRenderer] Renderer has been unconfigured due to the input format changing.
12-14 19:07:45.303 i: [ExoPlayer][EventLogger] tracksChanged [7.08, 0.00, window=0,
12-14 19:07:45.304 i: [ExoPlayer][EventLogger] Renderer:1 [
12-14 19:07:45.305 i: [ExoPlayer][EventLogger] Group:0, adaptive_supported=N/A [
12-14 19:07:45.306 i: [ExoPlayer][EventLogger] Track:0, id=0, mimeType=video/hevc, bitrate=1392000, codecs=hevc, res=1920x1080, fps=25.0, supported=YES
12-14 19:07:45.308 i: [ExoPlayer][EventLogger] ]
12-14 19:07:45.309 i: [ExoPlayer][EventLogger] Metadata [
12-14 19:07:45.309 i: [ExoPlayer][EventLogger] original_init_data: (Value: 0 Buffer: 86 bytes)
12-14 19:07:45.310 i: [ExoPlayer][EventLogger] scantype_progressive: (Value: 1 Buffer: 0 bytes)
12-14 19:07:45.311 i: [ExoPlayer][EventLogger] ]
12-14 19:07:45.312 i: [ExoPlayer][EventLogger] Renderer:3 [
12-14 19:07:45.313 i: [ExoPlayer][EventLogger] Group:0, adaptive_supported=N/A [
12-14 19:07:45.314 i: [ExoPlayer][EventLogger] Track:0, id=1, mimeType=audio/ac3, bitrate=1392000, codecs=ac3, channels=6, sample_rate=48000, supported=YES
12-14 19:07:45.314 i: [ExoPlayer][EventLogger] ]
12-14 19:07:45.315 i: [ExoPlayer][EventLogger] Metadata [
12-14 19:07:45.316 i: [ExoPlayer][EventLogger] block_align: (Value: 0 Buffer: 0 bytes)
12-14 19:07:45.320 i: [ExoPlayer][EventLogger] channel_layout: (Value: 1551 Buffer: 0 bytes)
12-14 19:07:45.327 i: [ExoPlayer][EventLogger] original_init_data: (Value: 0 Buffer: 0 bytes)
12-14 19:07:45.328 i: [ExoPlayer][EventLogger] ]
12-14 19:07:45.329 i: [ExoPlayer][EventLogger] ]
12-14 19:07:45.330 i: [ExoPlayer][EventLogger] ]
12-14 19:07:45.330 i: [Player][ExoPlayer] Setting initial track selection…
12-14 19:07:45.331 i: [Player][ExoPlayer] Switching video surface to use MediaCodec surface.
12-14 19:07:45.331 i: [Player] onSurfaceChangeRequested
12-14 19:07:45.527 i: [MediaCodecAudioSyncRenderer] Renderer has been unconfigured due to the input format changing.
12-14 19:07:45.856 i: [FF] Video decoder doesn’t support ac3 (audio/ac3).
12-14 19:07:45.858 i: [FF] Audio decoder doesn’t support ac3 (audio/ac3).
12-14 19:07:45.862 i: [FF] Video decoder doesn’t support hevc (video/hevc).
12-14 19:07:45.865 i: [FF] Video decoder doesn’t support ac3 (audio/ac3).
12-14 19:07:45.868 i: [FF] Audio decoder doesn’t support ac3 (audio/ac3).
12-14 19:07:45.871 i: [FF] Video decoder doesn’t support hevc (video/hevc).
12-14 19:07:45.874 i: [FF] Video decoder doesn’t support ac3 (audio/ac3).
12-14 19:07:45.877 i: [FF] Audio decoder doesn’t support ac3 (audio/ac3).
12-14 19:07:45.879 i: [FF] Video decoder doesn’t support hevc (video/hevc).
12-14 19:07:45.917 i: [ExoPlayer][EventLogger] surfaceSizeChanged [7.76, 0.00, window=0, 0, 0]
12-14 19:07:45.936 i: [ExoPlayer][EventLogger] timelineChanged [7.78, 0.00, window=0, periodCount=1, windowCount=1, reason=DYNAMIC
12-14 19:07:45.938 i: [ExoPlayer][EventLogger] period [2525.00]
12-14 19:07:45.939 i: [ExoPlayer][EventLogger] window [2525.00, true, false]
12-14 19:07:45.943 i: [ExoPlayer][EventLogger] ]
12-14 19:07:45.945 i: [Player][ExoPlayer] onTimelineChanged (Position: 0 ms)
12-14 19:07:45.951 i: [ExoPlayer][EventLogger] decoderInitialized [7.78, 0.00, window=0, video, OMX.amlogic.hevc.decoder.awesome]
12-14 19:07:45.952 i: [ExoPlayer][EventLogger] decoderInputFormatChanged [7.79, 0.00, window=0, video, id=0, mimeType=video/hevc, bitrate=1392000, codecs=hevc, res=1920x1080, fps=25.0]
12-14 19:07:45.952 i: [ExoPlayer][EventLogger] decoderInitialized [7.79, 0.00, window=0, audio, OMX.amlogic.audio.decoder.ac3]
12-14 19:07:45.957 i: [ExoPlayer][EventLogger] decoderInputFormatChanged [7.79, 0.00, window=0, audio, id=1, mimeType=audio/ac3, bitrate=1392000, codecs=ac3, channels=6, sample_rate=48000]
12-14 19:07:45.958 i: [TranscodeSession] Updating session status
12-14 19:07:45.959 i: [DisplayBehaviour] Mode found: 1920x1080 @ 60.0000Hz (1) (Score: 225.00 (RR: 100.00 R: 125.00)
12-14 19:07:45.960 i: [DisplayBehaviour] Best mode for 1920x1080 @ 60.000004Hz selected as 1920x1080 @ 60.0000Hz (1).
12-14 19:07:45.977 i: [DisplayBehaviour] Mode is already set to our best mode of 1920x1080 @ 60.0000Hz (1).
12-14 19:07:45.979 e: [ExoPlayer][EventLogger] playerFailed [7.82, 0.00, window=0]
12-14 19:07:45.980 e: An exception occurred: com.google.android.exoplayer2.i: java.lang.IllegalArgumentException
12-14 19:07:45.982 e: Stacktrace: com.google.android.exoplayer2.i: java.lang.IllegalArgumentException
at com.google.android.exoplayer2.o.handleMessage(SourceFile:397)
at android.os.Handler.dispatchMessage(Handler.java:102)
at android.os.Looper.loop(Looper.java:193)
at android.os.HandlerThread.run(HandlerThread.java:65)
Caused by: java.lang.IllegalArgumentException
at android.media.MediaCodec.native_setSurface(Native Method)
at android.media.MediaCodec.setOutputSurface(MediaCodec.java:1979)
at com.google.android.exoplayer2.video.e.a(SourceFile:1103)
at com.google.android.exoplayer2.video.e.a(SourceFile:511)
at com.google.android.exoplayer2.video.e.handleMessage(SourceFile:475)
at com.google.android.exoplayer2.o.e(SourceFile:973)
at com.google.android.exoplayer2.o.c(SourceFile:944)
at com.google.android.exoplayer2.o.b(SourceFile:926)
at com.google.android.exoplayer2.o.handleMessage(SourceFile:363)
… 3 more
12-14 19:07:45.986 e: [Player][ExoPlayer] Playback error detected
12-14 19:07:45.991 e: An exception occurred: com.google.android.exoplayer2.i: java.lang.IllegalArgumentException
12-14 19:07:45.993 e: Stacktrace: com.google.android.exoplayer2.i: java.lang.IllegalArgumentException
… 3 more
12-14 19:07:45.994 i: [Player][Timeline] Handling player error
12-14 19:07:45.994 i: [Player][Timeline] Playback stopped (error: true)
12-14 19:07:46.001 i: [PlaybackTimeBehaviour] Time: 0 IsStarted: false
12-14 19:07:46.052 i: Fetching [method:GET] https://192.168.1.42:32400/:/timeline?bufferedTime=512&duration=2525000&guid=com.plexapp.agents.themoviedb%3A%2F%2F70484%2F2%2F1%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F7501&playbackTime=0&playQueueItemID=Delay-1237935072&ratingKey=7501&state=stopped&time=0&timeStalled=7&token=...GrVa&X-Plex-Client-Identifier=b4d670e467dc2da9-com-plexapp-android&X-Plex-Token=...GrVa
12-14 19:07:46.083 i: [ExoPlayer][EventLogger] surfaceSizeChanged [7.92, 0.00, window=0, 100, 100]
12-14 19:07:46.090 i: [TranscodeSession] Direct Play
12-14 19:07:46.094 i: [ExoPlayer][EventLogger] decoderDisabled [7.93, 0.00, window=0, video]
12-14 19:07:46.095 i: [ExoPlayer][EventLogger] decoderDisabled [7.94, 0.00, window=0, audio]
12-14 19:07:46.112 i: [Player][Timeline] Player error not known by server, likely to be a client configuration error
12-14 19:07:46.113 i: [Player] Error reported: PlaybackInterrupted (null)
12-14 19:07:46.113 i: [Player][Timeline] Playback stopped (error: false)
12-14 19:07:46.118 i: [PlaybackTimeBehaviour] Time: 0 IsStarted: false
12-14 19:07:46.165 i: Fetching [method:GET] https://192.168.1.42:32400/:/timeline?bufferedTime=512&duration=2525000&guid=com.plexapp.agents.themoviedb%3A%2F%2F70484%2F2%2F1%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F7501&playbackTime=0&playQueueItemID=Delay-1237935072&ratingKey=7501&state=stopped&time=0&timeStalled=7&token=...GrVa&X-Plex-Client-Identifier=b4d670e467dc2da9-com-plexapp-android&X-Plex-Token=...GrVa
12-14 19:07:46.196 i: [TranscodeSession] Stopping…
12-14 19:07:46.197 i: [TranscodeSession] Session already stopped.
12-14 19:07:46.198 i: [Player][Error] Displaying player error…
12-14 19:07:46.253 i: [FF][MediaPeriod] Releasing.
12-14 19:07:46.254 i: [FF] Loading canceled (released: true)
12-14 19:07:46.260 i: [Player][LoadControl] Assumed Bitrate: 10000, Segment Count: 1171
12-14 19:07:46.261 i: [Player][LoadControl] Segment count: 1171
12-14 19:07:46.266 i: [FF] Releasing demuxer.
12-14 19:07:46.271 i: [FFmpeg] [INFO] Demuxer closing.
12-14 19:07:46.273 i: [FFmpeg] [INFO] Demuxer has been closed, interrupting FFmpeg…
12-14 19:07:46.389 i: [ExoPlayer][EventLogger] loading [8.23, 0.00, window=0, false]
12-14 19:07:46.395 i: [ExoPlayer][EventLogger] state [8.23, 0.00, window=0, true, IDLE]
12-14 19:07:48.590 i: [EngineEventManager] onPlaybackStopped: Closed
12-14 19:07:48.594 i: [Player][Timeline] Playback stopped (error: false)
12-14 19:07:48.599 i: [PlaybackTimeBehaviour] Time: 0 IsStarted: false
12-14 19:07:48.600 i: [TranscodeSession] Stopping…
12-14 19:07:48.600 i: [TranscodeSession] Session already stopped.
12-14 19:07:48.607 i: [WiFiLockBehaviour] Releasing WiFi lock since playback was stopped.
12-14 19:07:48.612 i: Fetching [method:GET] https://192.168.1.42:32400/:/timeline?bufferedTime=512&duration=2525000&guid=com.plexapp.agents.themoviedb%3A%2F%2F70484%2F2%2F1%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F7501&playbackTime=0&playQueueItemID=Delay-1237935072&ratingKey=7501&state=stopped&time=0&timeStalled=10&token=...GrVa&X-Plex-Client-Identifier=b4d670e467dc2da9-com-plexapp-android&X-Plex-Token=...GrVa
12-14 19:07:48.990 i: [HomeHubsManager] Item content source server://e874e2bb3d9bcae1c5c3dccafceb8c8c9a6ef3fd/com.plexapp.plugins.library has volatile hubs: marking as stale.
12-14 19:07:49.003 i: [MediaSessionHelper] Starting media session with tag: video
12-14 19:07:49.003 i: [MediaSessionHelper] Creating media session with tag: video
12-14 19:07:49.102 i: [MediaSessionHelper] Releasing media session with tag: video
12-14 19:07:49.108 i: [Player][LoadControl] Assumed Bitrate: 10000, Segment Count: 1171
12-14 19:07:49.111 i: [Player][LoadControl] Segment count: 1171
12-14 19:07:49.112 i: [Player][LoadControl] Assumed Bitrate: 10000, Segment Count: 1171
12-14 19:07:49.114 i: [Player][LoadControl] Segment count: 1171
12-14 19:07:49.184 i: [MemoryOptimisationBehaviour] Expanding memory cache.
12-14 19:07:49.186 i: [VideoAwakeBehaviour] Keep screen awake has been disabled.
12-14 19:07:49.187 i: [AudioFocusBehaviour] Behaviour being destroyed, giving up audio focus
12-14 19:07:49.200 i: [DisplayBehaviour] Reverting back to the original display mode.
12-14 19:07:49.218 i: [DisplayBehaviour] Selecting 1920x1080 @ 60.0000Hz (1) as the active mode.
12-14 19:07:49.447 i: Fetching [method:GET] https://192.168.1.42:32400/library/metadata/augmentations/1205?wait=1&X-Plex-Token=...GrVa
12-14 19:07:49.462 i: [PlayerService] onDestroy
12-14 19:07:49.479 e: Error fetching https://192.168.1.42:32400/library/metadata/augmentations/1205?wait=1&X-Plex-Token=...GrVa:
404 Not Found
12-14 19:07:49.520 i: [UpdateChannelsJob] Starting channel creation job 12-14 19:07:49.545 i: Resuming PreplayEpisodeActivity. 12-14 19:07:50.003 i: [UpdateChannelsJob] Syncing programs for channel Recommendations (id=23) 12-14 19:07:50.114 i: Fetching [method:GET] https://192.168.1.42:32400/hubs?X-Plex-Token=...GrVa 12-14 19:07:50.387 i: [FF] Releasing demuxer. 12-14 19:07:50.396 i: [FF] Releasing demuxer. 12-14 19:07:50.492 i: Fetching [method:GET] https://192.168.1.42:32400/library/metadata/7500?asyncAugmentMetadata=1&includeExternalMetadata=1&includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...GrVa 12-14 19:07:50.532 i: Fetching [method:GET] https://192.168.1.42:32400/library/metadata/7294?asyncAugmentMetadata=1&includeExternalMetadata=1&includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...GrVa 12-14 19:07:50.556 i: Fetching [method:GET] https://192.168.1.42:32400/library/metadata/7500?asyncAugmentMetadata=1&includeExternalMetadata=1&includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...GrVa 12-14 19:07:50.585 i: Fetching [method:GET] https://192.168.1.42:32400/library/metadata/7235?asyncAugmentMetadata=1&includeExternalMetadata=1&includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...GrVa 12-14 19:07:50.613 i: Fetching [method:GET] https://192.168.1.42:32400/library/metadata/7294?asyncAugmentMetadata=1&includeExternalMetadata=1&includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...GrVa 12-14 19:07:50.640 i: Fetching [method:GET] https://192.168.1.42:32400/library/metadata/7210?asyncAugmentMetadata=1&includeExternalMetadata=1&includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...GrVa 12-14 19:07:50.959 i: [UserAction] Navigate back. 12-14 19:07:51.025 i: Resuming HomeActivity. 12-14 19:07:51.034 i: [HomeHubsProvider] Reusing results from previous discovery. 12-14 19:07:51.035 i: [HomeHubsProvider] Starting new discovery task because there are stale content sources. 12-14 19:07:51.039 i: [DynamicHomeHubsDiscoveryTask] Not reusing hubs from server://e874e2bb3d9bcae1c5c3dccafceb8c8c9a6ef3fd/com.plexapp.plugins.library because it's a stale content source.This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
