Server Version#: 1.18.6.2368-97add474d
Player Version#: 6.4.10
Hello,
For a reason that i can’t understand… Roku app can’t play sound for french Track DTS but ok on English Track …
I also test on samsung App… and i can play the french track without any problem …
I test to change the audio track to english and come back to french but no change…
Here’s the mediainfo :
Format : Matroska
Format version : Version 4
File size : 3,28 Gio
Duration : 43 min 4s
Overall bit rate : 10,9 Mb/s
Encoded date : UTC 2017-06-04 03:52:28
Writing application : mkvmerge v8.3.0 (‘Over the Horizon’) 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Vidéo
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Oui
Format settings, Reference frames : 4 images
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 8 614 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate mode : Constant
Frame rate : 23,976 Im/s
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressif
Bits/(Pixel*Frame) : 0.173
Stream size : 2,59 Gio (79%)
Writing library : x264 core 150 r2829 d1fe6fd
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=8614 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : Anglais
Default : Oui
Forced : Non
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 canaux
Channel layout : C L R Ls Rs LFE
Sampling rate : 48,0 kHz
Frame rate : 93,750 Im/s (512 SPF)
Bit depth : 24 bits
Compression mode : Avec perte
Stream size : 237 Mio (7%)
Language : Français
Default : Oui
Forced : Oui
Audio #2
Format : DTS
Codec ID : A_DTS
Bit rate : 1 509 kb/s
Bit depth : 24 bits
Stream size : 465 Mio (14%)
Language : Anglais
Default : Non
Forced : Non
Texte #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 43 min 1s
Bit rate : 60 b/s
Count of elements : 600
Stream size : 19,1 Kio (0%)
Language : Français
Default : Non
Forced : Non
Texte #2
Format : UTF-8
Duration : 42 min 27s
Bit rate : 3 b/s
Count of elements : 46
Stream size : 1,11 Kio (0%)
Title : Forced
Language : Français
Default : Oui
Forced : Oui
Logs :
Plex Media Server Logs_2020-02-07_14-40-35.zip (130.8 KB) roku.log (124.4 KB)
Thanks!
