No TV media found
Hello,
Having only done the film part up until now, I’m now working on the series part.
The settings were already done, identical to the films.
But when I scan, it finds nothing.
An example tree structure
MEDIA
→ TV Show
→ Resident Alien (2021)
→ Season 3
→ Resident Alien 2021- S03E04 - Avian Flu WEBDL-1080p
May 21, 2025 00:07:38.801 [140280406420280] DEBUG - Request: [192.168.1.254:57639 (Subnet)] GET /library/sections/3/refresh (4 live) #11d TLS GZIP Signed-in Token (Obsyky)
May 21, 2025 00:07:38.802 [140280406420280] DEBUG - [Req#11d] Library Updater: Requested that section 3 be updated, force=0, subdir= iTunes=0
May 21, 2025 00:07:38.802 [140280406420280] DEBUG - [Req#11d] Library Updater: Queueing section 3
May 21, 2025 00:07:38.803 [140280451451704] DEBUG - Completed: [192.168.1.254:57639] 200 GET /library/sections/3/refresh (4 live) #11d TLS GZIP 1ms 320 bytes (pipelined: 2)
May 21, 2025 00:07:38.803 [140280416963384] DEBUG - Activity: registered new activity d36b8241-ac5a-4e92-b967-fbdf36dbd3a8 - "Scanning"
May 21, 2025 00:07:38.803 [140280416963384] DEBUG - Scanning section 3
May 21, 2025 00:07:38.804 [140280416963384] DEBUG - Activity: updated activity d36b8241-ac5a-4e92-b967-fbdf36dbd3a8 - completed 0.0% - Scanning Séries TV
May 21, 2025 00:07:38.804 [140280416963384] DEBUG - Job was already killed, not killing again.
May 21, 2025 00:07:38.804 [140280416963384] DEBUG - Asked to cull library timeline before time 1747777658, we're starting with 0 items.
May 21, 2025 00:07:38.804 [140280416963384] DEBUG - Library timeline cull complete with 0 items left.
May 21, 2025 00:07:38.804 [140280416963384] DEBUG - Scanning Séries TV using fr-FR(Plex TV Series) with 0 current media items and 2 section locations in the database.
May 21, 2025 00:07:38.804 [140280416963384] DEBUG - Performing a scan with 'Plex TV Series' (language: fr-FR virtual: 0).
May 21, 2025 00:07:38.804 [140280416963384] DEBUG -   * Scanning /tv\040shows
May 21, 2025 00:07:38.804 [140280416963384] DEBUG -   * Marking media not available in /tv\040shows
May 21, 2025 00:07:38.810 [140280416963384] DEBUG -   * Taking 0 items out of the map (which has 0 items) for being unavailable.
May 21, 2025 00:07:38.817 [140280416963384] DEBUG -   * Taking 0 directories out of the map (which has 0 dirs) for being unavailable.
May 21, 2025 00:07:38.817 [140280416963384] DEBUG - Activity: updated activity d36b8241-ac5a-4e92-b967-fbdf36dbd3a8 - completed 49.5% - Scanning Séries TV
May 21, 2025 00:07:38.817 [140280416963384] DEBUG - Performing a scan with 'Plex TV Series' (language: fr-FR virtual: 0).
May 21, 2025 00:07:38.817 [140280416963384] DEBUG -   * Scanning /TV\040Shows
May 21, 2025 00:07:38.817 [140280416963384] DEBUG -   * Marking media not available in /TV\040Shows
May 21, 2025 00:07:38.822 [140280416963384] DEBUG -   * Taking 0 items out of the map (which has 0 items) for being unavailable.
May 21, 2025 00:07:38.828 [140280416963384] DEBUG -   * Taking 0 directories out of the map (which has 0 dirs) for being unavailable.
May 21, 2025 00:07:38.828 [140280416963384] DEBUG - Activity: updated activity d36b8241-ac5a-4e92-b967-fbdf36dbd3a8 - completed 99.0% - Scanning Séries TV
May 21, 2025 00:07:38.828 [140280416963384] DEBUG - Scanner [Plex TV Series]: Idle and left with 0 media items.
May 21, 2025 00:07:38.828 [140280416963384] DEBUG - Removing 0 media items that were left.
May 21, 2025 00:07:38.828 [140280416963384] DEBUG - Removing 0 directories that were left.
May 21, 2025 00:07:38.834 [140280416963384] DEBUG - Collections: Found 0 collections tags in section 3.
May 21, 2025 00:07:38.834 [140280416963384] DEBUG - Collections: We had 0 collections in the library already.
May 21, 2025 00:07:38.834 [140280416963384] DEBUG - Collections: Synced tags in section 3 in 5ms.
May 21, 2025 00:07:38.839 [140280416963384] DEBUG - Collections: Found 0 collections tags in section 3.
May 21, 2025 00:07:38.839 [140280416963384] DEBUG - Collections: We had 0 collections in the library already.
May 21, 2025 00:07:38.839 [140280416963384] DEBUG - Collections: Synced tags in section 3 in 10ms.
May 21, 2025 00:07:38.844 [140280416963384] DEBUG - Collections: Found 0 collections tags in section 3.
May 21, 2025 00:07:38.844 [140280416963384] DEBUG - Collections: We had 0 collections in the library already.
May 21, 2025 00:07:38.844 [140280416963384] DEBUG - Collections: Synced tags in section 3 in 14ms.
May 21, 2025 00:07:38.859 [140280416963384] DEBUG - Collections: Refreshed attributes for 0 collections in section 3 in 15ms.
I don’t see any errors, just that it can’t find anything, and I don’t know how to solve the problem :confused:
Ty !
It appears Plex can’t see the media in this directory linked to your library.
Yet the folder has exactly the same rights as the movies folder, so I don’t know where the problem might come from :confused:
Given this is inside a container… how do you map the difference too-level folders into your container?
Did you check/compare permissions inside the container or the host OS?
Try to replace the character in the folder name between tv and shows. I have a hunch that this is the offending thing.
