Im shown as a tester in google play, but i was never able to get the beta
any help?
Do you have more than 1 Google account on your device? If so, please make sure you are checking the play store under the correct account.
You can also try checking the playstore from their website. Search for the Plex app and scroll down to Whats New. It should show the app version you will get. It should show the current beta which is 7.6.0. You can then push it to your device.
Yeap, only one account
Plex is showing 7.6.0.6822 in the app store in android updated on Sep 13, 2018
web version doesnt show but says updated september 10, web also not showing as beta
That’s the latest beta. If you see this, then you are in the beta program.
Ok, wow, i just verified, then its really strange that google is not showing as beta.
Im good then
thanks
Yeah. I see the same thing. The play store use to show a Beta tag just above the description. Not sure what happened. Just go by the version number and you should be fine.
