My question is related to the power needed to transcode.
Faqs say a benchmark of 2000 is enough but it doesn’t seem so according to my situation.
I need to understand if there is something wrong or the Faqs are just not correct and I need more power, in that case I would buy a more powerful mini pc for my plex server
Keep in mind the 2000 Passmark requirement is an indication.
Depending on the video’s technical specs the transcode might require more power.
Have you configured your server to actually use hw-accelerated streaming?
Also… there’s use cases where the iGPU cannot transcode your media (e.g. if there’s a requirement to burn a subtitle into your video). To help troubleshoot this… can you check the information showing in the “now playing” tile from the Plex dashboard while attempting to play that video and share that information?
HW transcoding does not work to burn subtitles into your video. Therefore your server has to rely only on the CPU.
You might try to set the playback quality for that video to 720p to see if the CPU can deal with encoding it in real-time. The reference Passcode score to transcode to 720p/h264 is lower, so this should be working with your CPU.
It’s the same client of yesterday. And the same video.
Also, if it’s not burning the subtitles, why it’s transcoding the video? The client supports h264 and if it turn off subtitles, it stops to transcode and it starts to direct play
