Not seeing my library after reinstall on truenas
Server Version#:Truenas Scale Dragonfish-24.04.2.5
Player Version#: 1.41.2.9200
I had to reinstall Truenas so I upgraded to Scale.
Now after numerous adjustments have installed Plex on it.
So I click the open Web portal so I can link everything it has me log in.
Then I click “Your media” and it takes me to install plex
I am using a Plex server installed on a Truenas Scale system. I don’t need to install again.
I have logged out/in and still get that only option.
Now after resetting the layout the add my library is gone.
When you reinstalled, did the ZFS pool containing your Plex metadata get destroyed ?
Looking at the plex.tv account for THIS email address, I find no servers .
Is the server claimed under a different email address ?
Yes it was destroyed or at least wiped when I recreated the pool.
And this address is what I used originally for my plex account.
I was hoping to just relink the server to the account.
But it seems to be in a endless loop.
How did you get to this point? Which URL?
https://global.discourse-cdn.com/plex/optimized/4X/7/8/c/78c4bd7fb08b9bab93431359868a8ae089c7b9cf_2_690x382.png
Did you open the server by its LAN IP or did you use a FQDN or app.plex.tv?
You should open via IP (on the same subnet) or http://127.0.0.1:32400/web if that applies in containers on TrueNAS containers.
You will need to completely recreate from scratch given the pool (and data) was destroyed
I am clicking “Web portal” from the app within the system-
On a laptop on the same network, my home, as the Truenas.
When I clicked the link this morning it loads me in but the same missing link.
So I tried a different Browser-
I click your media.
And back to the dang downloads again…
It is already downloaded and running… AHHHHHHHHHH
Did you see & review this?
Look from item 12 and below.
Plex Claim Token (has a 5 minute validity so don’t delay)
This will attach the server to your Plex account
Yeah I saw the checkbox my issue I can’t see the box to check.
That Config Volume isn’t showing anywhere.
And I just found out **Version:**Dragonfish-24.04.2.5
removed it from advanced settings.
But Reddit posts, and other forms postings are showing no new location.
so no way to disable to get plex to work. wonderful.
