quqdk
August 16, 2013, 3:01pm
1
I dont get this...
I have the following stuff:
Router with DD-wrt v24 sp2
Synology NAS DS212J /DSM 4.2
Appletv v3
PMS 0.9.8.3.96-eee3b6a (bought membership to get a new version)
Plexconnect 0.1-5
Python 2.7.5-6
In Putty SSH I have the following:
PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_dnsmaster = 8.8.8.8
ip_webserver = 0.0.0.0
loglevel = Normal
enable_dnsserver = False
ip_pms = 0.0.0.0 (Ive tried changing this to 192.168.1.102, but it didnt seem to have any effect)
port_webserver = 81
In the appletv settings I have manually changed DNS to 192.168.1.102 (my NAS).
I have followed the guide in DNS Server Package aswell, and stopped/removed the app, after done all the settings, as told.
Everything is up running without errors in the log files.
However, all I get it "Accessing Trailers" for ages, before finaly getting the "Trailers is unavailable. Try again later."
Am I doing an obvious error, or woot? :)
baa
August 16, 2013, 3:57pm
2
A PlexConnect.log might help...
When using "port_webserver=81", did you set up some port-forwaring on you NAS?
quqdk
August 16, 2013, 5:57pm
3
Well... I just updated the PMS to 0.9.8.4, and now I actually get to the point where I can see the library.
However I now have this message when trying to play a movie which isnt an mp4:
An error occured loading this content. Try again later.
I would love to give you the log files from both PSM and Plexconnect, but Im lost on how to retrieve them...?!
I have forwarded all ports to my NAS (at least I think so.. http://quq.dk/ports.jpg )
baa
August 16, 2013, 6:10pm
4
Your NAS is most probably not able to do "transcoding".
You have to run the PMS on a "powerful" machine that supports remuxing or even full transcoding - aTV only accepts m4v/mp4 and some http streaming stuff...
Edit: I have no idea about NAS port forwarding... so no answer on that one.
quqdk
August 16, 2013, 6:24pm
5
Hmm... interesting... so basicly the Synology DS212j can never be able to play avi files on an apple tv, because its too weak...
Which means that the only option I have is to either convert all my avi files to mp4 manually, or to not use plex..?
baa
August 16, 2013, 6:40pm
6
Well, I am not sure about your special NAS, but I guess, overall there is some truth in your words.
But then there is a 3rd option - run PMS on your desktop?
