Notification feature?
I normally leave my PC on all the time, occasionally resetting, what I would like, is when a friend connects to my server, a pop up from the task bar or w/e, would notify me that someone has connected, so i know not to reset or turn on my VPN.
Also a follow feature for people would be great, Example, new season of a TV show, they can follow and when a new episode is available, it will notify them of it or if a new movie in a category, action, is posted, it will notify them.
Take a look at Tautulli
Mowed lawn, check. Showered, check. Installed Tautulli, check. Thanks for the info and will be trying this out and seeing what it does over the next few weeks.
Also, will something like this eventually be built into the program itself ?
I can’t speak for Plex. Future plans are usually not revealed.
But I think it is safe to say that the full abilities of Tautulli won’t get implemented any time soon.
OK so got it set up to notify me via browser and discord, now plex is even better than before.
Thanks again
