Novaroma - Auto Download Tv Shows, Movies, Subtitles and watch TV with Plex
Pretty curious to give this a try. Can I remote manage? Or do I have to be on the local machine? I run a headless server so it would be fantastic if I didn’t have to log into that machine in order to manage the program.
Deleted.
I'd like to try but I have only linux.
Are you going to port this to Linux?
This sounds really great. Would love to use it. Waiting for Mac. Eta?
Thank you! We really want to port Novaroma to Linux and OS X but for now Mono does not support WPF, we are exploring options but this will take a lot of time, once we solve all existing issues then we could try porting (we wille have to create all UI from scratch).
P.S: We try our best to reply all feedbacks but we missed these posts, sorry!
@Frefbh
You're not alone. Same popup here on Windows 8.1
We are sorry for the inconvenience, we are not sure what causes this error, but we shared a portable version with Fred, here is the link.
We will create a portable version for next version, thank you for your interest.
Pretty curious to give this a try. Can I remote manage? Or do I have to be on the local machine? I run a headless server so it would be fantastic if I didn't have to log into that machine in order to manage the program.
For now, no :(
But we are working on a WebUI, we will release next version after it is completed. Polish, Italian and Russian translations will be ready too.
I have 2 folders with tv shows, how do I select those 2? I can only select one
@em17ah said:
You persuaded us, we added this to settings for movie and tv show episode (default is no renaming), now available with 0.9.4 version.
Thanks for feedback.
Novaroma.net
This is good news, what template should i be using for tv shows? i want to have “Showname - S00E00 - Episodename”.
Same story with the movies. They don’t seem to be renaming at the moment.
Also is it possible to remove the 0 in the season folder?
Thank you for an amazing product!
Are there dedicated forums for this? I would love to chat some more about it, also getting some random errors I’d love to research and sort out. (object reference not set to an instance of an object)
Do I have to use Utorrent?
Does anyone have further feed back if this is a program worth using? What torrent providers are available to search from and are you able to add your own?
I have been using couch potato for a few years now and was very happy with it until I upgraded to Windows 10. Now I can’t get movies to rename and move so I am looking for a replacement.
Hope someone might let me know their thoughts on this program.
Is this still a thing? I’ve been reading up on Couch Potato, but I’d rather have something streamlined for/with Plex.
Thank you for your effort.
After installing Novaroma i was able to use it just one time, because know it’s giving this error: the reference of the object isn’t defined as an instance.
Can you assist me with that, please?
Well, seems like they are a bit off. Trying to get contact with anyone close to information how to fix my prob. It cant search for any torrents cause the thepiratebay.vg is down. Its not using kickass unless you do it manually. All I get is a constant soound popout that it cant find any…
So… no mac osx?? And not much of a resonse lately… is this dead?
I am getting a few errors. The main one is that the remote server returned an error. (403) Forbidden.
Looks like this project is dead. When I switched from a Mac to Windows machine to download shows I had no idea it would be so hard to find a decent program to automatically download torrents. I had used Automatic 2 from CodingCurious on my MAC. I miss that so much I’m on my way to switching back to a Mac.
The 403 error Seems to be a normal occurrence, it loads the magnet into utorrent, and then if you have queueing set-up it downloads one by one
I thought I found the perfect software but its giving 403 all the time :frowning:
The 403 Forbidden error is coming from your Pirate Bay settings. Change the url to www.thepiratebay.se instead of www.thepiratebay.vg. I’m looking at the source code now…going to try to resurrect this a bit :wink:
Would love a mac version, showrss is getting spotty.
