Novaroma - Auto Download Tv Shows, Movies, Subtitles and watch TV with Plex
Aside from movies, what does this give me that Sonarr doesn’t?
Anyone has gotten this to work? Is it obsolete? Thanks.
i just downloaded it yesterday, i use it on my mac (in a vm through parallels) and it works great. super easy to use. it does constantly say “Object reference not set to an instance of an object” but i just mute the sound on the virtual machine and let it do it’s thing.
In the TV episode rename string, does anyone know what the variable is for the name of the series like Gotham for example. I have tried %name% and %TvShowId% and neither worked.
Quick question, if anyone is still listening. How do you go about removing a TV show from the database if it does not show up in your list of TV programs? I added the series “Damien” but when I do it does not show up in my list after saving, yet the activity window keeps showing me this error (Damien’ search result is empty. You can search again manually 2/25/2017 12:07:30 PM). At this point I would like to totally remove this series from novaroma but cannot because it doesn’t even show in my list of TV shows that it monitors. Is there a trick to getting this show to appear in the listings? I have tried adding it more than once and it never shows up in my list.
BTW - Damien is not the only series that will not show in the list when saved. There were a couple of others but I cannon remember what they were. They are not giving me problems like Damien because they were added in my first install of the novaroma software. That install got fudged somehow so I uninstalled and started from scratch.
ok …i tried on windows with bitorrent, is look like i cant make it work, i keep getting unable to retrieve webui token, downside i cant add my own sources for download
Sorry guys, but programs like that allow you to illegally download media goes against our Plex Guidelines. Closing this thread.
I have managed to use this for a few films, but i am now stuck, the movies and tv shows are showing up within the search option, but when it comes to edit where the movie will be saved, it just loads and loads and loads, and it never does anything.
Please help me to understand why!!
