Now Playing not properly updating,
This has been a longer running issue. the Now Playing section shows every single item ever played, even those that are no longer being played. So the list just grows and grows until the server is restarted. I believe started happening around version 1.12, and thought this was such an obvious bug it would have been fixed by now, but it still isn’t.
Bump. Still happening even after upgrade to new dashboard.
Are you letting the Title finish completely or are you intervening with back function. If your doing the latter you can, if you check stop prior to back.
Does it matter? Never used to. Plus it’s not just me it’s also the 40 or so people I share my server with. Who lets the file run all the way through the end through credits? Something has changed and now it shows tons of “now playing” when they aren’t.
How far along is the progress line in the now Playing Titles. Please illustrate? I don’t watch credits but use the stop function with good results.
It doesn’t matter. Can be fully played. The NewGirl in the pic below for example was finished watching last night as was the Maisel. Just stays there. The number of plying items just grows and grows and grows until the server is restarted.
BUMP, I cannot be the only one experiencing this.
