Number of versions/files missing from episodes
That little number in the upper left seems to have disappeared, as in, no matter if there’s 2 or 3 or 200 different files for the exact same episode of a show, it shows as a normal single-file episode. Using the “Get Info,” I can see that Plex has recognized the extra files and I can even select which one to play, but that number is still missing from view. Has it been removed, or is there something I need to do to fix it?
Apparently, it is an intended change in the web client
I understand it has a technical reason.
The available versions are now listed on the episode preplay pages.
