Version 1.29.0.1885-67668ec3
No longer shows the “2” in the top right corner of the episode poster when I have 2 copies of the same episode.
Thanks, Otto.
…a backwards step though in my opinion.
I agree with you JCHH. I often play an Episode directly from the Season page and have no reason to enter the “media details page” to see further information before I press play, however I am no longer aware that additional versions are available. Not ideal. It is also now difficult to clean up large seasons that have for example 20 episodes and you need to locate the small number that have duplicates (I worked around this by using a filter for “episode duplicates = true” and set the display to “Episodes”).
Maybe a good solution would be for the developers to add the number of duplicates to the “Detail View” on the season page (by default it displays the Grid View).
