Nvidia Shield 4k audio transcode AC3 issue
I am currently running PMS on an Nvidia shield (version 1.18.3.2156), connected via HDMI to a Samsung UE43NU7400.
4K content is served from a My Cloud NAS via gigabit Ethernet.
The video is able to direct play however any audio stream I use is always being transcoded to AAC. I expect this with TrueHD 7.1 but is this also expected with formats such AC3?
The rips I use have ~5 audio streams from 7.1 down to ac3.
Is there any setting in Plex or directly on the shield which will allow me to direct play both video and audio?
An AVR is not an option right now unfortunately.
An xml file for one of my rips is attached for reference.
Thanks,
P
3693.txt (45.3 KB)
On mine I found out have to to go to settings and pick audio 5.1 if it’s 7.1 the video don’t play. You have to stop the video and then do the settings it will not work if the video is still playing as you set this. I just have stereo too. The video looked bad no video just blocks of colors if playing a 7.1 audio.
-Raymond Day
Thanks for your reply.
Do you mean in the Plex client?
I have chosen AC3 as the audio stream. My issue is that the Plex server is transcoding AC3 down to AAC.
The audio transcode is what I am trying to avoid.
Did you enable pass-through in t he app and in your Shield audio settings?
I double checked these settings.
Pass through set to HMDI in the Plex app on the Shield.
Pass through set to Auto in the Shield settings.
Weirdly when i play back my test film, the Plex dashboard is not telling whether the video or audio is being transcoded or not.
Do you know why this is?
Thanks,
P
I looked up your TV. I can’t find anything saying it supports DTS or TrueHD. I see it supports AC3 so getting 5.1 AC3 is the correct result.
Do you know why the Plex dashboard is not show whether the video or audio is being transcoded?
Are you running the latest version of the app on the Shield.
I am running on this version, 7.26.0.14578.
It was updated last month I believe.
