Pplex on NVIDIA Shield - problem with transcoding kicking in for no reason
scenario 1
My Sheild output is set to 4k60hz - I play this movie and correctly drops into 4k23,976 hz and plays the movie but with terrible buffering, when I check my Plex servers it is transcoding.
Scenario 2
I manually set my sheild to 4k,23,976 and play the movie, it plays it locally on the sheild with no transcoding.
Anyone any idea what is going on here, it also does it with other movies, here is the movie relevant specs:
File size : 61.8 GiB
Duration : 2 h 43 min
Overall bit rate mode : Variable
Overall bit rate : 54.1 Mb/s
Frame rate : 23.976 FPS
Movie name : Blade Runner 2049
Encoded date : 2018-01-17 15:10:56 UTC
Writing application : MakeMKV v1.10.8 win(x64-release)
Writing library : libmakemkv v1.10.8 (1.3.5/1.4.7) win(x64-release)
Video
ID in the original source medi : 4113 (0x1011)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 49.5 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.249
Stream size : 56.5 GiB (91%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primar : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 457 cd/m2
Maximum Frame-Average Light Le : 179 cd/m2
Original source medium : Blu-ray
Audio
ID in the original source medi : 4352 (0x1100)
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 4 597 kb/s
Maximum bit rate : 5 022 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 5.25 GiB (8%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Text
ID in the original source medi : 4768 (0x12A0)
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 2 h 32 min
Bit rate : 14.9 kb/s
Frame rate : 0.213 FPS
Count of elements : 1950
Stream size : 16.3 MiB (0%)
Language : English
Default : No
Forced : No
