Occasionally only plays audio, have to reboot
I've found over the past couple of months (since 0.4.* I think) that occasionally, RasPlex will work fine for ages then after a while it'll start to only play audio on videos. It will continue to do that for every subsequent file I play, and the only way around it is to reboot. Anyone else get this? Is this a known issue?
Rasplex version: 0.4.1 (clean install)
PMS version: 0.9.9.14.531-7eef8c6 on unRaid
Usually indicates that it has run out of memory... Do you use the library artwork slideshow as your background?
Yes, it looks really fancy. Although I've noticed that occasionally that starts displaying blank images.
Are you going to suggest I disable that or is there another way around it (e.g. some kind of memory tweaking, or adjusting the caching for the slideshow somehow?)
