Server Version#:1.13.5.5332-21ab172de
I have a network range of 18.8.10.XXX and I am reading that if you have an odd address range you may not be able to find your server. What should I do?
I am using a Asustor NAS.
Plex implemented RFC1918 Private Network (home LAN) addressing rules.
This means:
If my understanding of the RFC1918 is correct I can use an address as long as the first numbers are 10. So if I use 10.18.8.XXX I will be good. Is this correct?
I am an AV contractor so I will be using Plex quite a bit in the future and I like my networks to be unique, so I can VPN from one to the other. I am still a networking neophyte so RFC1918 is new to me but I am always interested in learning something new.
Thank you.
Yes, you should be good using anything in 10.*.*.* as well as 192.168.*.*
RFC1918 states:
192.168.x.x
172.16.x.x -> 172.31.x.x
10.x.x.x
I changed it to start with 10. and it works. Thank you for your help. Have a great day.
