Odd transcode issues - only with a few movies
Server Version#:
This is my first post, so let me know if I’m in the wrong section.
Setup:
Unraid 6.10.3 - i5 8700k no GPU
Plex in docker (official Plex)
Transcoding to ram 2x16
Media files are in h.264 1080P
Using hardware acceleration
Tried playing these movies on a Sony and Hisense android TVs and my MacBook Pro.
I don’t have a lot of movies or shows, but I noticed about 6 of them are having troubles playing. I’ve downloaded the movies again and same errors:
Jun 26, 2022 17:07:25.894 [0x1467ae1fbb38] Error
  • [Transcoder] Error while decoding stream #0:0:
    Invalid data found when processing input
    Jun 26, 2022 17:07:25.894 [0x1467ae2aab38] Error
  • [Transcoder] [h264 @ 0x14a1a0c14240] Invalid
    NAL unit size (0 > 42191).
  • [Transcoder] [dca @ 0x14a1a0c436c01 Not a
    valid DCA frame
  • [Transcoder] [h264 @ 0x14a1a0c14240] Error
    splitting the input into NAL units.
When I try to play these movies I will get a loading symbol for awhile and then Plex will crash or give me an error message to try again.
I’ve tried:
  • restarting my server
  • deleting the files in the codecs folder and restarting Plex.
Since other files play OK, probably defective media.
The error message says, Invalid data found when processing input, which also points to the media files.
Some things to try:
  1. Acquire from a different source.
  2. Remux using MKVToolNix. Long shot, but it might work (if the problem is with the MKV container, not the individual tracks).
  3. Re-encode using Handbrake or similar tools. Might clean things up.
Looks like I’m unable to play any file that’s not h.265 and I’ve played these movies before
So any file that’s h.264, I can not view.
Most of my errors now will state:
  • Invalid NAL unit size
  • not a valid DCA frame
