Where can i Download the older Releases.
I got since the latest Release.
That should help you: https://forums.plex.tv/discussion/290924/howto-download-previous-plex-version
At this there are releases but Not as ohne file to copy to Programms and run it.
Library/Applications Support/Plex Media Server/Updates
What release you are looking for?
some from 11/2017 or before
Oh i Need this für Mac Not Windows
are you from Plex?
He’s just one of the volunteer support staff (unpaid) that’s trying to volunteer some support.
Plex doesn’t give a **** if it works or not.
also if i pay the plex pass? strange and embarrassing.
Forums are only way of support and Plex Pass has nothing do with you getting or not getting help.
Ok then thx for support
Version didnt help
Thx for support
What is the problem? Why you need older release?
Server Not found, this Message i get since Release 1.0
At my Mac at Library…PMS…Updates there are no Installer Files.
How are you accessing PMS, via plex.tv or localhost:32400/web on the machine where PMS is installed?
