Official PlexConnect Fanart views
The option only appears if ur PIL installation is functional and if yout ios is supported, my guess is that ur problem lies there
Like i have some movies with Greek text and in the fanartcache directory the image is there but the name is empty   +_1080.jpg but in the movies with english titles is like that Sharknado+2+The+Second+One_1080.jpg
Interesting discovery... and yes, that's what the code says: to generate the filename remove all characters from the title that's don't fit into std. ASCII. I guess, we need better way to create the cache file names.
Something like...
http://stackoverflow.com/questions/10150850/how-to-convert-strings-in-any-language-and-character-set-to-valid-filenames-in-j
http://stackoverflow.com/questions/295135/turn-a-string-into-a-valid-filename-in-python
Maybe don't use the title at all, just some hash-tag based on it?
Just made a interesting discovery with fanart. If you have "Require authentication on local networks" enabled in your PMS then the fanart image will produce just a black image due to a 401 error when plexconnect tries to retrieve the art image from PMS
11:28:52 XMLConverter: CCmds_getKey: /library/metadata/27240/art/1413073718,,False
11:28:52 XMLConverter: Background (Source): Gnomeo & Juliet // http://10.0.0.25:32400/library/metadata/27240/art/1413073718
11:28:52 PILBackgrounds: Check for Cachefile.
11:28:52 PILBackgrounds: No Cachefile found. Generating Background.
11:28:52 PILBackgrounds: Getting Remote Image.
11:28:52 PILBackgrounds: error: 401 Unauthorized // url: http://10.0.0.25:32400/library/metadata/27240/art/1413073718
11:28:52 PILBackgrounds: Merging Layers.
11:28:52 PILBackgrounds: Background size: 1920, 1080
11:28:52 PILBackgrounds: aTV Height: 1920, 1080
11:28:52 PILBackgrounds: Cachefile  generated.
11:28:52 XMLConverter: Background: http://trailers.apple.com/fanartcache/Gnomeo+Juliet_1080.jpg
11:28:52 XMLConverter: XML_ExpandLine: http://trailers.apple.com/fanartcache/Gnomeo+Juliet_1080.jpg - done
Remove the black image from the fanartcache directory, uncheck "Require authentication on local networks" in PMS, fanart will get the image with no problem
Baa if you use the original title ? i think its always in English text?
Also baa check the post of ScottC i think this is my problem of the black fanart
1) I wouldn't bet that the original title is always in English... there are much more countries around than just the US. :-D
2) We saw such an issue earlier already with different kinds of (transcoded) thumbs. We just need to add the "auth-thoken" to the file request...
baa with your latest commit the fanart is working again :)
Still the movies that have Greek text as title cant be opened.
Also i saw a strange graphic glitch?. When i go a tv show to see the seasons the fanart has some lines in the picture. (seasonview = Coverflow)
* Also it would be great if in coverflow the summary of the tv show can be displayed  :)
I have fanart showing correctly now with latest git pull,  but now there is nothing saved to the fanartcache directory. Not a huge issue for me.
Restarted PlexConnect fixed this.
Roidy,
The new TV Episode fanart/template appears to push the preview image (the image on the left side of the screen) down to the bottom of the screen rather than up near the episode title.
Roidy,
If you mean he preplay screen then yep, unfortunately that's the only place the aTV lets you put it :(
I'm guessing you're not on iOS 8 yet :) I'm working on it :)
..... Should be fixed now, please test and let me know.
roidy latest release fix the problem with the lines.
Also i saw that sometimes in an episode pre play display the trailer button. When i will see this again i will take a picture and post it
Great work guys. Given the constraints of the images and layout you’ve done an amazing job!
im not getting any fancy Fanart, What em i missing? Running the last pms Plex-Media-Server-0.9.914.531-7eef8c6-en-US, latest PlexConnect v4.0-dev,
Python version 2.7.6, and used this installer for Pillow: Pillow-2.2.1.win32-py2.7.exe (md5)
and AppleTV3 running 7.0.  \fanartcache folder is empty.
mvh bitzorro.
did u turn it on? :)
Python version 2.7.6, and used this installer for Pillow: Pillow-2.2.1.win32-py2.7.exe ([/size]md5)[/size]
and AppleTV3 running 7.0.  [/size]\fanartcache folder is empty.
mvh bitzorro.
That's the 32bit version of Pillow, so I assume both your OS and the installed version of python are 32bit as well.
And make sure to turn fanart on in both:-
Settings->Movie Options->Movie Fanart
Settings->TV Show Options->TV Show Fanart
Umm... the episode preplay screen has never had a trailer button.... maybe on one of the unofficial themes, but never on the official PlexConnect.
The Fanart option is not shown on my apple tv.
That's the 32bit version of Pillow, so I assume both your OS and the installed version of python are 32bit as well.And make sure to turn fanart on in both:-Settings->Movie Options->Movie FanartSettings->TV Show Options->TV Show Fanart
Cant find that otion in my settings menu.
The option only appears if ur PIL installation is functional and if yout ios is supported,, my guess is that ur problem lies there
Double check your installing the correct PIL/Pillow version for your python version
Roidy i am using the official release only.
The button of trailer in preplay screen was never in the official release neither on any other release. The button is appearing inside an episode menu.
I will delete everything and download the latest release again and i will let you know
