Officially deb repository for PlexMediaServer
Hello folks,
I would like to know if Plex has some official repository for debian packages, or any others. I found some old threads at Forum but links does not more working. So please give me some tips or links if exists.
Thank you
Server Version#: 1.14.1.5488
Player Version#:emphasized text
https://support.plex.tv/articles/235974187-enable-repository-updating-for-supported-linux-server-distributions/
To add to Tom’s reply,
I wish to add that the current (old CI build system) repository will return a Warning because there is no CodeName field in the descriptor file. This is a harmless warning.
When Ubuntu & Debian decided to start enforcing the need for this field (it was not previously required), we had already begun building the new CI system. It was decided to deploy all the update in the new repository with that new CI.
If you follow the “Hopefully smaller, faster…:” thread, you will see we are about to advance to full, formal, beta (Plex Pass) where this will be live.
Thank you, repository’s working fine (for ma Debian GNU/Linux 9 ) only one Issue is Warning as you talked before:
W: Conflicting distribution: https://downloads.plex.tv/repo/deb public InRelease (expected public but got )
Anyway I can see plexmediaserver in repository so hopefully will be fine.
Thank you for your support.
