Old Problem limited number of search results (30)
Hi i have PMS 1.32.4.7195-7c8f9d3b6 on Raspberry pi ( Raspbian GNU/Linux 10 (buster)) running.
Can anyone tell me how to remove the annoying search result restriction of 30 results? I am trying this since days now without any success. Even a complete reinstall of PMS and deleting Application folder did not have any effect.
Dear Plex Programmers: Please implement an user option for the amount of results on the interface since it is randomly happening to several users over the years. PLEASE!!! Lifetime is limited :)) THANK YOU :smiley:
PS: I cant find anything useful in preferences.xml or elsewhere…
This problem seems to be randomly hitting linux versions of PMS. The Windows Version on my (slow) Backup-Server is showing all files (59 instead 30). I very much hope anybody has got an other idea …
The limit is by design. There is no way to remove it.
The only way to actually find all matching items is to use the Custom Filters.
It must be a bug indeed. I just upgraded my Windows PMS Server to the latest Version (see first message (30 / 59 results ) and now it also gets only 30 results. Crap!
I have also a theory to this never versions of PMS in which the problem occurs. Maybe if the number of database entries gets above a certain amount ( btw. i have above 2000 entries) then it falls back to a certain max. search result limit (30) . So there MUST be a configfile anywhere to reconfigure. Otherwise i would not know how this could be done.
I am having the same issue. I want more than 30 results!!! If there is a technical reason why 30 results cant be shown at one time, what about pages of results?!?! Plus 30 seems such a small number of results to limit it too!
