On Deck Issues
Has anyone figured out how to make On Deck work properly?
In my mind, regardless of whether you order old to new or new to old, the first unplayed episode in that order should show up in On Deck. Most of mine are not showing up at all, though.
Same here.
Not a fix, but a temporary solution:
If you’re having this issue and want a particular episode to show up in On Deck, you can skip to 1 minute in and then just stop. That puts the episode in On Deck at the place you stopped it. That doesn’t fix the underlying problem, but at least it shows up.
