On Deck not updating?
when new shows were added they used to show up on deck if I had watched a previous episode. For example I watched last weeks episode of the last ship. When last nights episode was added this morning it does not show up on deck rather just as recently added tv. I have also noticed that entire series that I have started will not show up on deck even though they are marked as unwatched. another example would be Blakes 7. I had previously watched the entire series and marked it unwatched so I could start again. After the first 5 episodes it no longer appears on deck?
any ideas?
I got the same problem. Worked fine a couple of weeks ago, but now none of my shows turn up in “On Deck”
anyone have any ideas on what to check?
Only episodes which have a ‘Originally Available’ date set in their properties appear in OnDeck.
Check if the date is present.
If you are using Plex Home Theater to watch, switch to OpenPHT instead.
