On Deck suggesting next season's episode
Server Version#: 1.19.4.2935
Player Version#: 8.1.2.18135
When watching Specials seasons Plex will suggest the next episode of the next season.
For example, If I watch episode S00E01, On Deck will then suggest S01E02 when it should be suggesting S00E02.
I also had it suggest S01E12 when it should have suggested S00E02.
One other thing is that I have Optimized Versions (3 unwatched) set for these shows, not sure if it is relevant.
Has anyone experienced anything like this?
On Deck goes by air dates so it presents a mid season special in the correct order. What are the air dates of the episodes.
Ahh, that’s precisely it.
The reason it confused me is that Optimized Versions does not take air date into account while ‘on deck’ does
Thanks for solving this confusion BigWheel!
Incidentally, is there some way to customize On Deck behavior here?
There are some settings for On Deck behavior in your servers library settings but not for how it behaves regarding airdates.
Ok, thanks for the help BigWheel!
A related question here.
On Deck will show you the next show based on the air date, right?
However, when you are watching a show, the post-play ‘up-next’ screen won’t show these in chronological order. If you are in season 1, it won’t interlace specials.
Is there a reason for this inconsistent behavior between these two features?
