When you have a “Season 00” or “Specials” folder in a TV series, On Deck correctly shows the proper next episode, according to air date. After playing that episode, the post play screen wants to play the S01E01 episode as the next up item. I think play list for the post-play screen is generated automatically by the server, as it seems to affect all of the apps I tried it on (PlexWeb, Roku, Android TV)
When you back out of the post-play screen and return to the home page on the apps, the correct episode is shown in the “On Deck” section according to air date.
Any chances we can get someone to look at the way the post-play generated list considers the air date as well as season/episode? I understand that some series are sorted by DVD order, which might affect the logic required, but I’m sure the devs can come up with something that works for all
EDIT: it also works incorrectly the other way around, “Special” episodes are not displayed in the post play screen where the should be. Example: S00E05 should play after S02E10, but the play list shows S02E11.
