On-going connection issues
No, it’s DSM provided by Synology as a download. I am not sure now how to get to the ssh command line. I am currently in the PlexMediaServer folder, ready to run DBRepair.
Ahhh I seem to have lost access to the NAS as well, I get this from Terminal:
cd /Volumes/PlexMediaServer
cd: no such file or directory: /Volumes/PlexMediaServer
I have tried the drag-and-drop Mac method of using the path to access the server, but it doesn’t always seem to work, and I get the same output as typing it in by hand. Am I missing something?
Volume1 not Volumes
I think I am back where I want to be now, later today I will try DBRepair (I have somewhat limited time on the computer atm). Does this look right? :
baward@Mac-mini ~ % ssh cinerama21@192.168.178.35 -p 15
cinerama21@192.168.178.35’s password:
Using terminal commands to modify system configs, execute external binary
files, add files, or install unauthorized third-party apps may lead to system
damages or unexpected behavior, or cause data loss. Make sure you are aware of
the consequences of each command and proceed at your own risk.
Warning: Data should only be stored in shared folders. Data stored elsewhere may be deleted when the system is updated/restarted.
cinerama21@NAS:~$
Yes it does.
I am finally running DBRepair after spending some time getting to the right folder on my NAS. Being used to a GUI, makes a command line interface a bit of a steep learning curve, even though I have now done it several times. I think I will do a course onMac Terminal…
Trumpy81 previously helpfully pointed out that it is not generally a good idea to have more than a single user in a particular account. I previously had my partner as a separate user to me, as they often watch the same TV shows, but at a much different rate (i.e. pace of watching episodes in a series). This led to many frustrating & brain-stretching weeks of attempting to solve various playback/access issues, as evidenced from this long thread. After several weeks now of ok-ish operation, today, I made the simple change of deleting the second user from my account, and hey presto, (almost) completely normal service has resumed, with no domestic difficulties resulting either :wink: Once more, many thanks to all who helped us out previously. I just wanted to flag this in case anyone else is struggling.
