Version#: 1.30.1.2115-81e1fc3f
Please bear with me as this is a quirky problem to explain:
Desired behavior: when watching live TV the audio stream should remember the selected audio stream and not change by itself
Actual behavior: when I start watching a broadcast TV station the audio stream changes by itself to one labeled as Spanish. (In my case the label is also not correct; the actual signal on that audio stream is one with descriptions for the visually impaired, in English, but that is a separate issue)
If I open the settings and change to the correct audio stream it works, until I stop playing the live TV. When I start again the stream has spontaneously changed back to the incorrect one.
