Under the program guide tab the “on right now” section only shows that will be starting in XX amount of minutes. Once a new show starts it disappears and the next show on that channel replaces it, starting in xx amount of minutes. When you try to play it it says “unable to tune channel (not on air)”. Isn’t this section supposed to be where the currently playing shows are? I’ve refreshed the program guide and deleted/re-added my tuner several times. Using a Wintv Dualhd tuner running Plex on Windows 10.
I have this same problem, posted a similar question and still haven’t gotten any response. Really frustrating.
Can post more information such as screenshots? My On Right Now shows only currently airing shows, under the Starting Soon it shows any shows that are starting in xx minutes.
Here is a screenshot. As you can see nothing is actually on right now so I can’t tune channels.
Is the time correct on your Plex Media Server? I adjusted my servers time and got a similar display, not quite the same because I had shows currently airing but I did see quite a few shows in the on right now section that said starts in X minutes.
