Hi today I saw One Piece metadata from the new feauture where you can watch it from crunchyrool too and its metadata is really better than mine. I use Tvdb to name episodes and create seasons but it sucks with One Piece. It cuts marineford in two seasons and there are a lot of seasons for the first arc. besides that I like the fact that in there it is split in arcs but I can still see the episodes in absulute number. I’ve been putting the absulute number in the title but it’s a pain, sometimes when the title is too big I can’t even see the number. Is there any way to use whatever agent its being used there without spliting tv shows and animes. To the other animes I like the result.
There is the “Absolute episode ordering” on TheTVDB, which can be selected per tv show in Plex.
https://thetvdb.com/series/one-piece/seasons/absolute/1
(I don’t know if this ordering is in any way correct)
You will still have to name your files to follow the Plex naming schema.
If I do that I’ll lose the arc/season separation. I want both. Like this new source they have the seasons separation more precise and even with a season separation inside they have the episode with absolute order. Do you know what agent is plex using for this new feature and can I use it just on this show? Plex offers crunchyroll as alternative stream service but I think they use another Agent for this
Not sure if this is better? One Piece (TV Series 1999- ) - Seasons — The Movie Database (TMDB)
Yes I came to that too. Its the movie data base indeed. I’m trying to make it just for this show
This is the default metadata source in Plex if you use the new metadata agent.
https://support.plex.tv/articles/migrating-a-tv-library-to-use-the-new-plex-tv-series-agent-scanner/
