One specific device doesn’t connect to server
I hooked up an IPhone 14 Pro to my Plex server a few days ago which worked perfectly fine.
Now I am trying to do the same thing with an IPhone 14 Pro Max and I just can’t get it to work.
It shows my server after logging (pic 1) in but it can’t reach the sources (pic 2). So I am logged into the right account and I can also see that there is a new IPhone which has access to my account. But still no media there. It also says „offline“ for my server (pic 3).
Plex-Server Version is the newest and client too.
Tried 2,4ghz and 5ghz network.
Manually adding the server doesn’t work .
On the IPhone that now has functioning access you can see that the Plex app has access to the local network but on the other one it doesn’t even ask for that…
I think this might be an odd iOS problem, I have had no problems for years across multiple ipads and now both ipads and my iphone 12 show my server offline. Windows PC can see the server without any problem
