Czech language broke this beta plugin. I think there are missing strings and when user try open serie info, plugin stop responding. After delete czech folder and plugin revert to eng, everything work like before.
@danjames92 Not sure what youāre talking aboutā¦
@CooLajz Thanks for reporting.
Theres another release, 0.0.102b4. This fixes some issues with server decisions failing.
Finally got around to trying this. I am happy to say multi-part movies (sample size 1) work at last! Thanks.
@keithah said:
@danjames92 Not sure what youāre talking aboutā¦@CooLajz Thanks for reporting.
Not seeing it in the repo?
Any progress on that reload button? Feel like the skin hangs on exit cause the processes donāt cleanly shut down when auto updates occur.
Its definitely there⦠Even though Iām mostly using PKC lately for Alexa support, I installed 0.0.102b4 a few hours ago and am using it now.
@HitsVille said:
@danjames92 said:
Not seeing it in the repo?Its definitely there⦠Even though Iām mostly using PKC lately for Alexa support, I installed 0.0.102b4 a few hours ago and am using it now.
I checked for updates and itās not showingā¦
Checked 2 devices as well, weird.
@danjames92 said:
Mmmm Ok. I have actually reinstalled LibreElec a few times since I last used PlexForKodi. So in my case it was a fresh install of the testing repo rather than an update. So a different scenario I guess. Sorry mate! ![]()
From the Repo
Check for some caching. Mine updated fine.
Sorry, forgot to code block:
<addon id="script.plex" name="Plex" version="0.0.102b4" provider-name="Plex">
The latest build is working awesome for me.
I found a few nits that by no means should be given any priority, especially over plex companion
Not sure if this is a Kodi issue but the background images donāt load. Or if they do they are blurred to no recognition
When you create a library sort that includes āAllā you have to exit the library and reload for scrolling to work properly.
All the plex clients I have (Roku, Shield, FireTV, Windows) remove leading blank spaces on the library titles. Leading spaces allow you to sort your libraries without having to add a ā1.ā or āA.ā etc. But this client leaves the spaces in putting the library titles off center and making it look weird. Would it be possible to have leading spaces removed?
Like I said nothing important especially once the companion is working
thnks
@danjames92 I just updated on Kodi 17.0 and I have to go to the addons list, not the home screen menus, open the side menu, and click check for updates. If I try from the addon description it does not update. I would say this is a kodi bug.
- All the plex clients I have (Roku, Shield, FireTV, Windows) remove leading blank spaces on the library titles. Leading spaces allow you to sort your libraries without having to add a ā1.ā or āA.ā etc. But this client leaves the spaces in putting the library titles off center and making it look weird. Would it be possible to have leading spaces removed?
I have also noticed the leading spaces. You are doing a great job guys, keep it up.
Thanks for all the tips folks but nothing works so I reflashed LibreELEC and itās now working again.
Iām still on 0.0.101. No updates in kodi repo on nvidia shield. I even uninstalled and reinstalled kodi
If you are on 101 then your using the official Repo. If you want the beta builds you need to install the beta Repo. Its in the second post of this thread.
As I mentioned before, when returning to the home screens I get the no content message behind the contentā¦
Anyone seeing this on embedded using search with a keyboard ?
When actually typing it creates a shadow effect on whatās actually being typed.
However when moving off the typing panel it corrects itself.
Similar on Hungarian⦠I translate it to hungarian and i translate all lines, no missing things. But the problem definetally the translation.
There is a bug where if you Hide seasons, episodes will not play at all.
(TV Shows/Edit Library/Advanced/Seasons/Hide)
I just tried PlexKodiConnect - primarily for the Plex Companion. Itās actually pretty good.
However Plex for Kodi is still the superior and more elegant way to maximize the strengths of Plex and of Kodi. What @keithah and @ruuk have developed should be fully funded and supported by Plex (I hope it is). Down the road Iād like to see some of the android TV features that Plex has incorporated into their client developed for Plex for Kodi.
Nice job guys
