I have been using the XBMC software bundled in the Linux OpenELEC package. Its small footprint and stable functionality is perfect for my ASUS C60M1-i based computer.
I prefer the User Cuddliness of PLEX however and I'd like to install that.
Is there an OpenELEC style package for the PLEX Media Center?
No there is not. I have been trying to build PHT on OpenELEC, but its currently limited by the little time I have for it, so that should hopefully be possible in the future. I have hit small audio bugs etc when building the image, but PHT can be compiled in place of XBMC. Rasplex is also based on OpenELEC.
You lost me after "not", but thanks Mark for your reply and continuing efforts x
Basically I just wrote I have been working on what you were looking. For but the with the next version of Plex Media Center which is called Plex Home Theater (PHT) :)
PleXBMC is entirely different from what you posted. PleXBMC ties Plex services into standard XBMC. What you linked to installs Plex Media Server on OpenELEC. Totally different.
Same here: I would love to replace my old MacMini with a slim Linux install with PHT.
I am in a similar boat. I run OpenElec at the min with the XBMCPlex addon but I still prefer the proper plex client. Watched state not been set and issues with subs in some cases is driving me nuts. 90% of subs work just the shows i really want dont :)
Also i find the short eps with long credits don't get marked as watched so i need to mark them as watched on my phone.
I would suggest most of you go with PleXBMC and OpenELEC
Basically because both are actively maintained (OpenELEC just bumped to 3.2.0), I doubt any derivate of OpenELEC will get as much attention as the main OS
Only thing missing is an Plex skin clone that supports PleXBMC out of the box (I'd suggest using Amber which has excellent Plex support and reminds a lot of PHT)
/Mark
I've updated the source to OE 3.2 and that merge broke my branch. So I have redone everything and changed the PHT compile to use new build method that OE 3.2 uses. Also reusing a lot of the configuration that xbmc bring to OE, so I don't know if this will run or explode. I'm still having an issue with compressing textures for the theme, so I have a temporary fix for that. The build compiles successfully, but I haven't tested it yet. I can upload the latest target that completed later today. It should end up here http://plexrpms.markwalker.dk/OpenELEC probably in a 3.2 folder or similar. Work is moving forward, and hopefully next month I can afford the switch box it need to hook up all my devices to my cinemadisplay, so I can do testing more efficiently.
