[OpenPHT 1.6.0] Cannot switch to windowed-mode anymore, ALT+ENTER
Hey guys,
been using OpenPHT 1.5.0 very happily for a long time, everything worked great. Yesterday i updated to 1.6.0 and i cannot switch the application into windowed-mode anymore by pressing ALT+ENTER.
I use that a lot when i dont want to leave PHT but have to do something in the OS quick. Going into the video options and changing to windowed there is not really a solution, by that time i could just quit and restart PHT.
Am i missing something? Is it supposed to work in 1.6.0 or has something changed in that way? I tried to change ‘exclusive fullscreen’ and other options like that, no change.
I updated the skin and also my GeForce drivers.
OS is Windows 10 10586.338, OpenPHT 1.6.0, BlackEdition Skin,GeForce drivers 368.39.
Issue already raised https://github.com/RasPlex/OpenPHT/issues/65
Regards
As a workaround, you could use
[Alt+Tab] to switch to a different program window which might be already open underneath PHT or
[Win] which makes the taskbar visible
On top of that 1.6.0 ignores also multiscreen settings. I had to change from windowed to Full screen #3. Starting playback moves full screen back to main screen (#2). After restarting app OpenPHT comes back on full screen #3 and sometimes after starting playback back to screen 2.
Could you please add additional information to the Github issue.
Regards
