OpenPHT 1.6 Embedded Nvidia_Legacy.x86_64
Hello,
Are there plans to release a Nvidia_Legacy.x86_64.img.gz version for Embedded? If I missed a post, please forgive me.
The nvidia legacy and generic build have merged, you can use the generic build if you were previously using the nvidia legacy build. I would however recommend a clean install instead of an upgrade.
See this issue https://github.com/RasPlex/OpenPHT/issues/68.
No need for seperate version.
Regards
Cool, I had previously used the Nvidia legacy build, the generic would not work of course. This sounds great, looking forward to using the new version. Thank you for your quick response and help.
