Hello!
I have just found out about the RasPlex project and recently received a Raspberry Pi B (Original, 512MB actually 256MB, 2USB, 100MB ethernet) and flashed an SD card with it to try out.
I am running PMS 1.0, which was released last week sometime.
I flashed several different versions of RasPlex attempting to get one to work, I have had the following issue with all of these versions: 1.6.2, 1.6.1, 1.6.0, 1.0.3.
Currently, when I turn on the Pi, the screen flashed the initial RasPlex (or the others one for 1.0.3) and then changes to the OpenPHT screen. At this point the system no longer progresses. I can see activity lights blinking on the box, but it is unresponsive to SSH, keyboard or mouse, or anything.
I have flashed 2 separate SD cards, one 16GB one 64GB. Both of them I verified are Class 10. My power supply is 5V 1A. The Raspberry Pi runs Raspbian just fine, I am able to get online, run terminal commands and everything, just RasPlex doesn’t work.
If anyone has any suggestions or comments I would be thrilled to have an answer, even if it is that I have something that is incompatible. I have spent hours trying to get this to work and just want to know “why?”
Thanks in advance!
Rhys
