OpenPHT vs PMP
Hi
Sorry if this is explained in some FAQ or previus post.
I have acctually never used PMP. I used to have Plex Home Theater and then went straight to OpenPHT.
Every now and then i have a choppy playback, both 1080P and 720P MKVs.
I havent been able to find the reason for it, but thats not my question.
What im wondering is:
Are OpenPHT and PMP using the same “engine”?
If I was to try PMP, would there be any differnce in actual playback, or are we just talking about different UI?
Thank you for any help with these noob questions
OpenPHT was based on xbmc (now Kodi). PMP is based on mpv. Completely different open source players.
Thx for your answer.
Playback wise, which one would be the better?
I prefer PMP
I just downloaded PMP to see if there’s a difference between the two.
Got sound but picture’s black unless I run at 60 instead of 23,976.
Also no settings in regards to subtitles running to slow/fast.
Any ideas about the two above problems?
So far I’m staying with OpenPHT
OpenPHT plays all my stuff. 10 foot interface and integration with MC remote is excellent. Plays all the sound fields on my movies. I don’t have 4k, and use an av receiver with Dolby decoding
PMP has improved, but I don’t like the interface, and it does not integrate with WMC… even lacking latest and greatest, OPHT is still my choice. Most of the new things I don’t really care that much about, and have Rokus anyway if I want those features
I agree, still using OPHT as well. But there are a few things not working fully,:
Often have to fix n trix with sub, being out of sync.
I have a permanent mod on audio, otherwise out of sync.
Even with WMC/MCE I didnt have these issuies, and that was ten years ago
I’ve been using PMC, PHT and OpenPHT since the very beginning and I’ve never had audio sync issue. I’ve only had to set my audio delay in PHT to 300ms since I have room correction done in pre-pro.
I’ve always used various nVidia HDMI-out to pre-pro (or receiver) and let processor in the audio equipment to do the job with audio.
I’m actually not using any amp/receiver at all, just Logitech Z5500 (I think) connected via spdif. The problem with sync I think, is due to “adjust display refresh rate”. When on I have to put in “audio offset” -475 ms and then it’s almost spot on. But to be able to just use my old MCE-remote, there’s also a lot of settings in “audio output” that need to be correct to control volume etc.
Every now and then sub is also completely out of sync.
All n all, lurve OpenPHT, but I’ve never had these problems before with other players
I get the same black screen with refresh switch in PMP, however sticking at 60 seems to be pretty solid on my NUC and with a fixed delay for spdif audio set that seems to be ok too. I don’t mind PMP for playback and actually quite like the new playnext and episode view for tv but the big killer for me is that PMP doesn’t allow me to limit hevc direct to something my player can handle, whereas openpht does. That’s the biggest issue for playback for me. As for the PMP menu navigation…its pretty horrible with my harmony remote, to the point where I use the laptop and plexweb to control the player for anything more than basic on deck/newly added playing. Open pht is so much easier zipping around my media but sometimes the audio engine seems to crash, requiring a reboot, but PMP doesn’t have that issue. All in all I am on the fence for now using both and waiting patiently for progress in either program to swing me one way or the other.
Completely missed your reply!
Sorry, but I don’t understand what you mean with “limit hevc”.
Regarding black screen or sticking with 60 is a no go for me. Just not acceptable, but still wondering what’s wrong.
Until I figured it out, I’m definitely staying with OPHT
MPV is an awesome player. I use it when I open files - seems very light and fast. OpenPHT is much heavier - though with some files to edit I was able to apply my own theme (edited version of NightGIT skin) and enable full time clock/time remaining display whilst watching content.
So OpenPHT was better in that regard, but MPV is a better software and lighter on resources.
I used to be a stickler for using the correct framerate but after a while I decided that the reduced flicker of 60 vs 24 was worth any other downside.
With regards to the “limit hevc” I mentioned, its the feature in OPHT quality settings section where you can say what resolution of HEVC you want to allow to play without transcoding. For my NUC5 Celeron I had to keep it at 720p as 1080p 10bit HEVC was too heavy for it to play direct as it didn’t do 10bit in hardware…
I have, just upgraded to a NUC7 J5005 and that will play 10bit in hardware however now OPHT doesn’t seem to work with the hardware decoding so it plays everything software :frowning:
PMP works fine with hardware decoding on it so I have had to switch to that but its just so sluggish with my harmony remote the extra clicks are painful to say the least. So much so I have just loaded kodi and the plex add-on. Initial trials look, its quicker and playback looks promising but the interface is poor when moving between lots of libraries and theres no way to reorder or hide any under a … menu like PMP…theres always something!!
Will there be additional releases of OpenPHT? I love it on RasPlex on my RPi3+, but it hasn’t been updated in a long time…
