Optimiser - Unable to convert
where do i start, i am getting the least helpful message
the logs only state :
May 16, 2019 22:18:37.281 [0x7fc19effd700] ERROR - [Transcoder] /mnt/movies/Plex Versions/Optimized for TV/.inProgress/NAME.mp4.12: No such file or directory
no ■■■■ genius - you are supposed to write the file at that location !
May 16, 2019 23:34:54.362 [0x7f0ed5f85700] DEBUG - Jobs: ‘/usr/lib/plexmediaserver/Plex Transcoder’ exit code for process 29979 is -11 (signal: Segmentation fault)
May 16, 2019 23:34:54.363 [0x7f0eabfff700] DEBUG - Transcoder: Cleaning old transcode directories.
May 16, 2019 23:34:54.363 [0x7f0e9b7fe700] DEBUG - Streaming Resource: Terminated session 0x7f0eb010d2c0:c6f14b7e-122c-4a09-8233-b824e166a326 with reason Conversion failed. The transcoder process crashed.
May 16, 2019 23:34:54.363 [0x7f0e99ffb700] DEBUG - Killing job.
May 16, 2019 23:34:54.364 [0x7f0e99ffb700] DEBUG - Signalling job ID 29979 with 9
May 16, 2019 23:34:54.364 [0x7f0e99ffb700] DEBUG - Job was already killed, not killing again.
May 16, 2019 23:34:54.364 [0x7f0e99ffb700] DEBUG - Stopping transcode session c6f14b7e-122c-4a09-8233-b824e166a326
May 16, 2019 23:34:54.364 [0x7f0eabfff700] DEBUG - Transcoder: Cleaning old transcode directory: “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-c6f14b7e-122c-4a09-8233-b824e166a326-3e78c288-362c-460a-9629-32a27be57d83”
May 16, 2019 23:34:54.367 [0x7f0eabfff700] DEBUG - Whacked session c6f14b7e-122c-4a09-8233-b824e166a326, 0 remaining.
got this from the debug log
