Good day, I am running into an issue where certainly videos cannot be optimized on my unraid server running Plex 1.12.0.4829. The video queues up, then immediately goes to -128066813652%, and then fails a bit after.
Now, this is not the case with all items, as some have no issues doing so. Best I can tell, it seems to fail in the following scenario:
- Have a 1080p movie existing, and added to Plex normally.
- Delete 1080p copy directly from disk at a later point, and paste 4k copy into the folder.
- Plex sees 4k copy no problem.
- Failure to optimize the 4k copy.
I create a new Plex server on Windows 10 Pro x64, and added this same 4k file, and had no issues optimizing.
I also had a couple other movies in 1080p that I later added 4k copies, then removed the 1080p copies using the Plex interface. These 4k copies had no problems optimizing.
I tried cleaning bundles, emptying trash, and optimizing the database, but this did not resolve the issue.
I have attached logs, but I am not sure which ones to look through, as there are quite a few.
Thank you much!
