Server Version#: 1.41.4.9399
I can’t seem to find an option to limit just the number of x265-transcodes, it always effects x264 too.
Is it possible to differentiate via the Preferences.xml, if yes how?
Thank you ![]()
Thank you ![]()
There is not
Such an option would be very good indeed.
Even better also the possibility to give different limits for different resolutions.
The number the GPU is capable of typically differs a lot between 4K, 1080p, 720p and SD.
