Options to change the quick-forward and quick-backward duration?
Inside of various players, you can skip forward, or skip backward a small amount. For instance, in the Windows Plex App, while watching video, you can press the right arrow, and by default, it goes forward 30 seconds. You can press the left arrow and go backward 10 seconds.
What I want to know is whether or not I can change the actual value of the time duration used in these functions? At a bare minimum, I would like them to match. Forward 10 seconds, and backward 10 seconds. Or 5, or 30. Having them be different values makes no sense.
I can’t find it anywhere in settings. Is it there and I’m just not seeing it? Or, is there maybe an .ini file somewhere I can change it?
Thanks in advance,
HaeSuse
I’ll take radio silence as “we haven’t got a clue”. :wink:
No, it doesn’t currently exist. I think the silence is because there’s already a feature suggestion for this in the forum.
Cool. I didn’t see anything, but it’s a hard one to search for “Quick-forward” was the only thing I could think of, to name it.
