Orange Pi
Will RasPlex work with Orange Pi?
I currently have Lubuntu installed and I installed Plax Media Server Following the Raspberry 2 guide and the install was flawless, BUT for some reason even with the server running I can’t access localhost:43200/web it just says “connection refused”.
Any ideas?
On a way to get plex to work?
Unless you typed the port wrong, the plex default port is 32400.
Are you trying to run PMS or Rasplex? You can’t run both…
Sorry, I had the right port in my browser. Just typed it wrong in the question.
This question is no longer relevant. I figured it out, I had lubuntu loaded and when installing the PMS I was using wheezy instead of Jessie. Once I corrected that it installed and is working fine.
Thanks for the reply! :slight_smile:
Cool, glad you figured it out. :slight_smile:
