Recently I cannot load PLEXWEB or see my TOMATOUSB 2TB storage on just one server in my network!
What setting do they have in common? I have checked router firmware settings in Port Forwarding and consulted it’s forum on Linksys, Youtube and Googled a bit.
I think I can provide a log too!
I dont get it.
What do you want with plex/web in Rasplex? I dont understand your problem.
Ya it does look complicated but I just wanted to specify software and hardware. Its just that when I right click the PLEX tray icon then the web page shows ‘Unable to connect’ and ‘Firefox can’t establish a connection to the server at 127.0.0.1:32400’ i.e. I can’t load PLEX!
Additionally the network icon for the USB storage is absent-meaning I can’t access that either.
These conditions are only on this PC-the others are fine. Are they symptoms of the same problem somehow?
Any ideas? Thanks in advance!
Wow…pls
Sort out your thoughts.
Are you sure ‘rasplex’ is the right form for your problem?
You say “127.0.0.1:32400 cannt reached by firefox”. The the server running on the same machine?
I’m using the latest update (auto) of Rasplex on my Raspberry pi 1. Am I in the right Forum? I’m using TomatoUSB on my router and it’s associated torrent downloader Transmission. Can I show you a log of something?.
Ya I’m trying to explain too much at once!
Questions please?
@kolossboss said:
Wow…plsSort out your thoughts.
Just can’t access my TomatoUSB HD!
Rasplex accesses a Plex server. It does not access a “TomatoUSB HD” whatever that is. There is no PLEXWEB in Rasplex.
What server version are you running? What box is running PMS? If you are having PMS issues then you are in the wrong forum.
So which Forum will address my concerns do tell thankee thankee?
As this seems to have nothing at all to do with Rasplex try posting in the General Discussion section, someone may understand what you are talking about.
Regards
So which Forum will address my concerns pray tell thankee thankee?
Sounds like you’re running the Plex Server on Windows? Perhaps you should ask your question here:
https://forums.plex.tv/categories/windows
This forum is for the Linux Plex client on a Raspberry Pi.
