When I use plex on PS4 the screen is too big for my TV (the edges are cut off). When I look in my PS4 settings for screen size they are correct. Is there a way I can correct this?
Our TV's here sometimes need the screensize changed. For instance our LG WebOS TV defaults to 16:9 screensize which crops off the edges. When I change it to Just Scan then everything is peachy. You may have similar options on your TV.
Ah I see. You think the TV is doing the oversizing and not the App? I will give it a try.
