Package plexmediaserver-1.43.0.10389-8be686aa6.x86_64 does not verify
Server Version#:Version 1.43.0.10346
Player Version#:N/A
dnf localinstall plexmediaserver-1.43.0.10389-8be686aa6.x86_64.rpm
Last metadata expiration check: 1:31:34 ago on Thu 04 Dec 2025 11:06:21 AM MST.
Dependencies resolved.
Package Architecture Version Repository Size
Upgrading:
plexmediaserver x86_64 1.43.0.10389-8be686aa6 @commandline 103 M
Transaction Summary
Upgrade 1 Package
Total size: 103 M
Is this ok [y/N]: y
Downloading Packages:
Running transaction check
Transaction check succeeded.
Running transaction test
Error: Transaction test error:
package plexmediaserver-1.43.0.10389-8be686aa6.x86_64 does not verify: Payload SHA256 ALT digest: BAD (Expected e463f006b392af87bfea354dc43ef14799cdaa4522c6f95b527c509722039ce3
28282987aa10ef6fe6e44c6230d003eb76e4fd4a541b69af7d63b477917c7ad2)
As its a sha256 checksum error I suspect the rpm is corrupt. My rpm sizes are below …
[plex]-[dokuro]:/data/Personal/Scripts]$ ls -lh ../Software/fedora/plexmediaserver-1.43.0.10389-8be686aa6.x86_64.rpm
-rw-r--r-- 1 plex plex 104M Dec  3 18:00 ../Software/fedora/plexmediaserver-1.43.0.10389-8be686aa6.x86_64.rpm
[plex]-[dokuro]:/data/Personal/Scripts]$ ls -la ../Software/fedora/plexmediaserver-1.43.0.10389-8be686aa6.x86_64.rpm
-rw-r--r-- 1 plex plex 108368751 Dec  3 18:00 ../Software/fedora/plexmediaserver-1.43.0.10389-8be686aa6.x86_64.rpm
Delete the file, download it again and try the install again.
Extremely odd.
Redownloaded, same behavior. Size matched your files. Deleted file, redownloaded. Worked.
Redownloading, without manually deleting the old file did not work. Not sure I understand what was happening. Appreciate the support.
bill.
I’d suggest running a disk check on the drive. This type of odd behaviour maybe a early symptom of a drive failure.
